net: hisilicon: fix handling platform_get_irq result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
drivers/net/ethernet/hisilicon/hip04_eth.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/hisilicon/hip04_eth.c b/drivers/net/ethernet/hisilicon/hip04_eth.c
index cc2d8b4..253f8ed 100644
--- a/drivers/net/ethernet/hisilicon/hip04_eth.c
+++ b/drivers/net/ethernet/hisilicon/hip04_eth.c
@@ -816,7 +816,7 @@ static int hip04_mac_probe(struct platform_device *pdev)
struct net_device *ndev;
struct hip04_priv *priv;
struct resource *res;
- unsigned int irq;
+ int irq;
int ret;
ndev = alloc_etherdev(sizeof(struct hip04_priv)); |
- unsigned int irq;
+ int irq;
int ret;
