[media] m5mols: introduce missing initialization
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The result of one call to a function is tested, and then at the second call
to the same function, the previous result, and not the current result, is
tested again.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression ret;
identifier f;
statement S1,S2;
*ret = f(...);
if (\(ret != 0\|ret < 0\|ret == NULL\)) S1
... when any
*f(...);
if (\(ret != 0\|ret < 0\|ret == NULL\)) S2
Signed-off-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/i2c/m5mols/m5mols_core.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/media/i2c/m5mols/m5mols_core.c b/drivers/media/i2c/m5mols/m5mols_core.c
index ac7d28b..0f521f5 100644
--- a/drivers/media/i2c/m5mols/m5mols_core.c
+++ b/drivers/media/i2c/m5mols/m5mols_core.c
@@ -937,7 +937,7 @@ static int __devinit m5mols_probe(struct i2c_client *client,
 	if (!ret)
 		ret = m5mols_init_controls(sd);
-	m5mols_sensor_power(info, false);
+	ret = m5mols_sensor_power(info, false);
 	if (!ret)
 		return 0;
 out_me:
BtrLinux
Privacy Overview
