ASoC: imx-sgtl5000: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize ret on the second call to imx_audmux_v2_configure_port so that
the subsequent test checks that result and not the previous one.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
sound/soc/fsl/imx-sgtl5000.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/sound/soc/fsl/imx-sgtl5000.c b/sound/soc/fsl/imx-sgtl5000.c
index fb21b17..199408e 100644
--- a/sound/soc/fsl/imx-sgtl5000.c
+++ b/sound/soc/fsl/imx-sgtl5000.c
@@ -94,7 +94,7 @@ static int __devinit imx_sgtl5000_probe(struct platform_device *pdev)
dev_err(&pdev->dev, "audmux internal port setup failed\n");
return ret;
- imx_audmux_v2_configure_port(ext_port,
+ ret = imx_audmux_v2_configure_port(ext_port,
IMX_AUDMUX_V2_PTCR_SYN,
IMX_AUDMUX_V2_PDCR_RXDSEL(int_port));
if (ret) { |
return ret;
if (ret) {
