[media] drivers/media/video/s5p-fimc/fimc-capture.c: adjust double test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Rewrite a duplicated test to test the correct value
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E;
* E
  || ... || E
* E
  && ... && E
Signed-off-by: Julia Lawall
Acked-by: Kyungmin Park
Signed-off-by: Marek Szyprowski
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/s5p-fimc/fimc-capture.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/media/video/s5p-fimc/fimc-capture.c b/drivers/media/video/s5p-fimc/fimc-capture.c
index 510cfab..a9e9653 100644
--- a/drivers/media/video/s5p-fimc/fimc-capture.c
+++ b/drivers/media/video/s5p-fimc/fimc-capture.c
@@ -693,7 +693,7 @@ static int fimc_pipeline_try_format(struct fimc_ctx *ctx,
 			mf->code = 0;
 			continue;
-		if (mf->width != tfmt->width || mf->width != tfmt->width) {
+		if (mf->width != tfmt->width || mf->height != tfmt->height) {
 			u32 fcc = ffmt->fourcc;
 			tfmt->width  = mf->width;
 			tfmt->height = mf->height;
@@ -702,7 +702,8 @@ static int fimc_pipeline_try_format(struct fimc_ctx *ctx,
 					       NULL, &fcc, FIMC_SD_PAD_SOURCE);
 			if (ffmt && ffmt->mbus_code)
 				mf->code = ffmt->mbus_code;
+			    mf->height != tfmt->height)
 				continue;
 			tfmt->code = mf->code;
@@ -710,7 +711,7 @@ static int fimc_pipeline_try_format(struct fimc_ctx *ctx,
 			ret = v4l2_subdev_call(csis, pad, set_fmt, NULL, &sfmt);
 		if (mf->code == tfmt->code &&
-		    mf->width == tfmt->width && mf->width == tfmt->width)
+		    mf->width == tfmt->width && mf->height == tfmt->height)
 			break;
BtrLinux
Privacy Overview
