i2c-dev: Use memdup_user
Author: Thomas Meyer <thomas@m3y3r.de>
Use memdup_user rather than duplicating its implementation.
This is a little bit restricted to reduce false positives.
The semantic patch that makes this output is available
in scripts/coccinelle/api/memdup_user.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
Signed-off-by: Jean Delvare
drivers/i2c/i2c-dev.c | 13 ++++---------
1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/drivers/i2c/i2c-dev.c b/drivers/i2c/i2c-dev.c
index 57a45ce8..10e7f1e 100644
--- a/drivers/i2c/i2c-dev.c
+++ b/drivers/i2c/i2c-dev.c
@@ -251,15 +251,10 @@ static noinline int i2cdev_ioctl_rdrw(struct i2c_client *client,
if (rdwr_arg.nmsgs > I2C_RDRW_IOCTL_MAX_MSGS)
return -EINVAL;
- rdwr_pa = kmalloc(rdwr_arg.nmsgs * sizeof(struct i2c_msg), GFP_KERNEL);
- if (!rdwr_pa)
- return -ENOMEM;
- if (copy_from_user(rdwr_pa, rdwr_arg.msgs,
- rdwr_arg.nmsgs * sizeof(struct i2c_msg))) {
- kfree(rdwr_pa);
- return -EFAULT;
+ rdwr_pa = memdup_user(rdwr_arg.msgs,
+ rdwr_arg.nmsgs * sizeof(struct i2c_msg));
+ if (IS_ERR(rdwr_pa))
+ return PTR_ERR(rdwr_pa);
data_ptrs = kmalloc(rdwr_arg.nmsgs * sizeof(u8 __user *), GFP_KERNEL);
if (data_ptrs == NULL) { |
return -EINVAL;
- if (!rdwr_pa)
- return -ENOMEM;
- kfree(rdwr_pa);
- return -EFAULT;
