[media] drivers/media/platform/soc_camera/soc_camera.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
[g.liakhovetski@gmx.de: follow the soc_camera.c style: check "ret < 0"]
Signed-off-by: Guennadi Liakhovetski
Signed-off-by: Mauro Carvalho Chehab
drivers/media/platform/soc_camera/soc_camera.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/media/platform/soc_camera/soc_camera.c b/drivers/media/platform/soc_camera/soc_camera.c
index 96c3c6e..d3f0b84 100644
--- a/drivers/media/platform/soc_camera/soc_camera.c
+++ b/drivers/media/platform/soc_camera/soc_camera.c
@@ -1184,7 +1184,8 @@ static int soc_camera_probe(struct soc_camera_device *icd)
sd->grp_id = soc_camera_grp_id(icd);
v4l2_set_subdev_hostdata(sd, icd);
- if (v4l2_ctrl_add_handler(&icd->ctrl_handler, sd->ctrl_handler, NULL))
+ ret = v4l2_ctrl_add_handler(&icd->ctrl_handler, sd->ctrl_handler, NULL);
+ if (ret < 0)
goto ectrl;
/* At this point client .probe() should have run already */ |
+ if (ret < 0)
goto ectrl;
