[media] drivers/media/usb/gspca/cpia1.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Hans de Goede
Signed-off-by: Mauro Carvalho Chehab
drivers/media/usb/gspca/cpia1.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/media/usb/gspca/cpia1.c b/drivers/media/usb/gspca/cpia1.c
index 2499a88..b3ba47d 100644
--- a/drivers/media/usb/gspca/cpia1.c
+++ b/drivers/media/usb/gspca/cpia1.c
@@ -751,7 +751,7 @@ static int goto_high_power(struct gspca_dev *gspca_dev)
if (signal_pending(current))
return -EINTR;
- do_command(gspca_dev, CPIA_COMMAND_GetCameraStatus, 0, 0, 0, 0);
+ ret = do_command(gspca_dev, CPIA_COMMAND_GetCameraStatus, 0, 0, 0, 0);
if (ret)
return ret; |
return -EINTR;
if (ret)
return ret;
