leds: wm831x-status: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
Also, remove platform_set_drvdata from probe function and the remove
function, wm831x_status_remove as it is now has nothing to do.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-wm831x-status.c | 13 +------------
 1 file changed, 1 insertion(+), 12 deletions(-)
diff --git a/drivers/leds/leds-wm831x-status.c b/drivers/leds/leds-wm831x-status.c
index 64a2226..be93b20 100644
--- a/drivers/leds/leds-wm831x-status.c
+++ b/drivers/leds/leds-wm831x-status.c
@@ -239,7 +239,6 @@ static int wm831x_status_probe(struct platform_device *pdev)
 			       GFP_KERNEL);
 	if (!drvdata)
 		return -ENOMEM;
-	platform_set_drvdata(pdev, drvdata);
 	drvdata->wm831x = wm831x;
 	drvdata->reg = res->start;
@@ -284,7 +283,7 @@ static int wm831x_status_probe(struct platform_device *pdev)
 	drvdata->cdev.blink_set = wm831x_status_blink_set;
 	drvdata->cdev.groups = wm831x_status_groups;
-	ret = led_classdev_register(wm831x->dev, &drvdata->cdev);
+	ret = devm_led_classdev_register(wm831x->dev, &drvdata->cdev);
 	if (ret < 0) {
 		dev_err(&pdev->dev, "Failed to register LED: %d\n", ret);
 		return ret;
@@ -293,21 +292,11 @@ static int wm831x_status_probe(struct platform_device *pdev)
 	return 0;
-static int wm831x_status_remove(struct platform_device *pdev)
-	struct wm831x_status *drvdata = platform_get_drvdata(pdev);
-	led_classdev_unregister(&drvdata->cdev);
-	return 0;
 static struct platform_driver wm831x_status_driver = {
 	.driver = {
 		   .name = "wm831x-status",
 	.probe = wm831x_status_probe,
-	.remove = wm831x_status_remove,
 module_platform_driver(wm831x_status_driver);
BtrLinux
Privacy Overview
