leds: lp8788: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
Also, remove platform_set_drvdata in probe function and the remove
function, lp8788_led_remove as it is now has nothing to do.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
.probe = probefn,
.remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
drivers/leds/leds-lp8788.c | 14 +-------------
1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/drivers/leds/leds-lp8788.c b/drivers/leds/leds-lp8788.c
index 0eee38f..38c253a 100644
--- a/drivers/leds/leds-lp8788.c
+++ b/drivers/leds/leds-lp8788.c
@@ -146,15 +146,13 @@ static int lp8788_led_probe(struct platform_device *pdev)
mutex_init(&led->lock);
- platform_set_drvdata(pdev, led);
ret = lp8788_led_init_device(led, led_pdata);
if (ret) {
dev_err(dev, "led init device err: %d\n", ret);
return ret;
- ret = led_classdev_register(dev, &led->led_dev);
+ ret = devm_led_classdev_register(dev, &led->led_dev);
if (ret) {
dev_err(dev, "led register err: %d\n", ret);
return ret;
@@ -163,18 +161,8 @@ static int lp8788_led_probe(struct platform_device *pdev)
return 0;
-static int lp8788_led_remove(struct platform_device *pdev)
- struct lp8788_led *led = platform_get_drvdata(pdev);
- led_classdev_unregister(&led->led_dev);
- return 0;
static struct platform_driver lp8788_led_driver = {
.probe = lp8788_led_probe,
- .remove = lp8788_led_remove,
.driver = {
.name = LP8788_DEV_KEYLED,
if (ret) {
return ret;
if (ret) {
return ret;
return 0;
- return 0;
.driver = {
