leds: max8997: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
Also, remove platform_set_drvdata in probe function and the remove
function, max8997_led_remove as it is now has nothing to do.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-max8997.c | 14 +-------------
 1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/drivers/leds/leds-max8997.c b/drivers/leds/leds-max8997.c
index 01b45906..4edf74f 100644
--- a/drivers/leds/leds-max8997.c
+++ b/drivers/leds/leds-max8997.c
@@ -281,30 +281,18 @@ static int max8997_led_probe(struct platform_device *pdev)
 	mutex_init(&led->mutex);
-	platform_set_drvdata(pdev, led);
-	ret = led_classdev_register(&pdev->dev, &led->cdev);
+	ret = devm_led_classdev_register(&pdev->dev, &led->cdev);
 	if (ret < 0)
 		return ret;
 	return 0;
-static int max8997_led_remove(struct platform_device *pdev)
-	struct max8997_led *led = platform_get_drvdata(pdev);
-	led_classdev_unregister(&led->cdev);
-	return 0;
 static struct platform_driver max8997_led_driver = {
 	.driver = {
 		.name  = "max8997-led",
 	.probe  = max8997_led_probe,
-	.remove = max8997_led_remove,
 module_platform_driver(max8997_led_driver);
BtrLinux
Privacy Overview
