staging: comedi: drivers: amplc_pci230: Prefer using macro DIV_ROUND_UP
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
The macro DIV_ROUND_UP performs the computation
(((n) + (d) - 1) /(d)). It clarifies the divisor calculations.
This was done using the coccinelle script:
expression e1;
expression e2;
- ((e1) + e2 - 1) / (e2)
+ DIV_ROUND_UP(e1,e2)
- ((e1) + (e2 - 1)) / (e2)
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/comedi/drivers/amplc_pci230.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/comedi/drivers/amplc_pci230.c b/drivers/staging/comedi/drivers/amplc_pci230.c
index d1fe88a..907c39c 100644
--- a/drivers/staging/comedi/drivers/amplc_pci230.c
+++ b/drivers/staging/comedi/drivers/amplc_pci230.c
@@ -642,7 +642,7 @@ static unsigned int pci230_divide_ns(uint64_t ns, unsigned int timebase,
case CMDF_ROUND_DOWN:
break;
case CMDF_ROUND_UP:
- div += (rem + timebase - 1) / timebase;
+ div += DIV_ROUND_UP(rem, timebase);
break;
return div > UINT_MAX ? UINT_MAX : (unsigned int)div; |
break;
case CMDF_ROUND_UP:
break;
