leds: bcm6328: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each
iteration, so a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_available_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-bcm6328.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/leds/leds-bcm6328.c b/drivers/leds/leds-bcm6328.c
index 18de094..c7ea5c6 100644
--- a/drivers/leds/leds-bcm6328.c
+++ b/drivers/leds/leds-bcm6328.c
@@ -403,8 +403,10 @@ static int bcm6328_leds_probe(struct platform_device *pdev)
 			rc = bcm6328_led(dev, child, reg, mem, lock,
 					 blink_leds, blink_delay);
-		if (rc < 0)
+		if (rc < 0) {
 			return rc;
 	return 0;
BtrLinux
Privacy Overview
