leds: 88pm860x: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
Also, remove platform_set_drvdata in probe function and the remove
function, pm860x_led_remove as it is now has nothing to do.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-88pm860x.c | 12 +-----------
 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/drivers/leds/leds-88pm860x.c b/drivers/leds/leds-88pm860x.c
index 1ad4d03..77a104d 100644
--- a/drivers/leds/leds-88pm860x.c
+++ b/drivers/leds/leds-88pm860x.c
@@ -195,7 +195,6 @@ static int pm860x_led_probe(struct platform_device *pdev)
 		sprintf(data->name, "led1-blue");
 		break;
-	platform_set_drvdata(pdev, data);
 	data->chip = chip;
 	data->i2c = (chip->id == CHIP_PM8606) ? chip->client : chip->companion;
 	data->port = pdev->id;
@@ -208,7 +207,7 @@ static int pm860x_led_probe(struct platform_device *pdev)
 	data->cdev.brightness_set_blocking = pm860x_led_set;
 	mutex_init(&data->lock);
-	ret = led_classdev_register(chip->dev, &data->cdev);
+	ret = devm_led_classdev_register(chip->dev, &data->cdev);
 	if (ret < 0) {
 		dev_err(&pdev->dev, "Failed to register LED: %d\n", ret);
 		return ret;
@@ -217,21 +216,12 @@ static int pm860x_led_probe(struct platform_device *pdev)
 	return 0;
-static int pm860x_led_remove(struct platform_device *pdev)
-	struct pm860x_led *data = platform_get_drvdata(pdev);
-	led_classdev_unregister(&data->cdev);
-	return 0;
 static struct platform_driver pm860x_led_driver = {
 	.driver	= {
 		.name	= "88pm860x-led",
 	.probe	= pm860x_led_probe,
-	.remove	= pm860x_led_remove,
 module_platform_driver(pm860x_led_driver);
BtrLinux
Privacy Overview
