KVM: VMX: Add missing braces to avoid redundant error check
Author: Jan Kiszka <jan.kiszka@siemens.com>
The code was already properly aligned, now also add the braces to avoid
that err is checked even if alloc_apic_access_page didn't run and change
it. Found via Coccinelle by Fengguang Wu.
Signed-off-by: Jan Kiszka
Signed-off-by: Gleb Natapov
 arch/x86/kvm/vmx.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/x86/kvm/vmx.c b/arch/x86/kvm/vmx.c
index 1cf202c..669b803 100644
--- a/arch/x86/kvm/vmx.c
+++ b/arch/x86/kvm/vmx.c
@@ -6785,10 +6785,11 @@ static struct kvm_vcpu *vmx_create_vcpu(struct kvm *kvm, unsigned int id)
 	put_cpu();
 	if (err)
 		goto free_vmcs;
-	if (vm_need_virtualize_apic_accesses(kvm))
+	if (vm_need_virtualize_apic_accesses(kvm)) {
 		err = alloc_apic_access_page(kvm);
 		if (err)
 			goto free_vmcs;
 	if (enable_ept) {
 		if (!kvm->arch.ept_identity_map_addr)
BtrLinux
Privacy Overview
