drivers/video/wm8505fb.c | 79 ++++++++++++------------------------------------
1 file changed, 19 insertions(+), 60 deletions(-)
diff --git a/drivers/video/wm8505fb.c b/drivers/video/wm8505fb.c
index fe9afd6..020df1d 100644
--- a/drivers/video/wm8505fb.c
+++ b/drivers/video/wm8505fb.c
@@ -272,15 +272,11 @@ static int wm8505fb_probe(struct platform_device *pdev)
unsigned long fb_mem_len;
void *fb_mem_virt;
- ret = -ENOMEM;
- fbi = NULL;
fbi = devm_kzalloc(&pdev->dev, sizeof(struct wm8505fb_info) +
sizeof(u32) * 16, GFP_KERNEL);
if (!fbi) {
dev_err(&pdev->dev, "Failed to initialize framebuffer device\n");
- ret = -ENOMEM;
- goto failed;
+ return -ENOMEM;
strcpy(fbi->fb.fix.id, DRIVER_NAME);
@@ -306,31 +302,14 @@ static int wm8505fb_probe(struct platform_device *pdev)
fbi->fb.pseudo_palette = addr;
res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- if (res == NULL) {
- dev_err(&pdev->dev, "no I/O memory resource defined\n");
- ret = -ENODEV;
- goto failed_fbi;
- res = request_mem_region(res->start, resource_size(res), DRIVER_NAME);
- dev_err(&pdev->dev, "failed to request I/O memory\n");
- ret = -EBUSY;
- goto failed_fbi;
- fbi->regbase = ioremap(res->start, resource_size(res));
- if (fbi->regbase == NULL) {
- dev_err(&pdev->dev, "failed to map I/O memory\n");
- ret = -EBUSY;
- goto failed_free_res;
+ fbi->regbase = devm_request_and_ioremap(&pdev->dev, res);
+ if (fbi->regbase == NULL)
+ return -EBUSY;
np = of_parse_phandle(pdev->dev.of_node, "default-mode", 0);
if (!np) {
pr_err("%s: No display description in Device Tree\n", __func__);
- ret = -EINVAL;
+ return -EINVAL;
@@ -349,7 +328,7 @@ static int wm8505fb_probe(struct platform_device *pdev)
ret |= of_property_read_u32(np, "bpp", &bpp);
if (ret) {
pr_err("%s: Unable to read display properties\n", __func__);
+ return -EINVAL;
of_mode.vmode = FB_VMODE_NONINTERLACED;
@@ -363,12 +342,12 @@ static int wm8505fb_probe(struct platform_device *pdev)
/* try allocating the framebuffer */
fb_mem_len = of_mode.xres * of_mode.yres * 2 * (bpp / 8);
- fb_mem_virt = dma_alloc_coherent(&pdev->dev, fb_mem_len, &fb_mem_phys,
+ fb_mem_virt = dmam_alloc_coherent(&pdev->dev, fb_mem_len, &fb_mem_phys,
GFP_KERNEL);
if (!fb_mem_virt) {
pr_err("%s: Failed to allocate framebuffer\n", __func__);
return -ENOMEM;
fbi->fb.var.xres_virtual = of_mode.xres;
fbi->fb.var.yres_virtual = of_mode.yres * 2;
@@ -379,28 +358,29 @@ static int wm8505fb_probe(struct platform_device *pdev)
fbi->fb.screen_base = fb_mem_virt;
fbi->fb.screen_size = fb_mem_len;
- if (fb_alloc_cmap(&fbi->fb.cmap, 256, 0) < 0) {
- dev_err(&pdev->dev, "Failed to allocate color map\n");
- ret = -ENOMEM;
- goto failed_free_io;
- wm8505fb_init_hw(&fbi->fb);
fbi->contrast = 0x80;
ret = wm8505fb_set_par(&fbi->fb);
if (ret) {
dev_err(&pdev->dev, "Failed to set parameters\n");
- goto failed_free_cmap;
+ return ret;
+ if (fb_alloc_cmap(&fbi->fb.cmap, 256, 0) < 0) {
+ dev_err(&pdev->dev, "Failed to allocate color map\n");
+ return -ENOMEM;
+ wm8505fb_init_hw(&fbi->fb);
platform_set_drvdata(pdev, fbi);
ret = register_framebuffer(&fbi->fb);
if (ret < 0) {
dev_err(&pdev->dev,
"Failed to register framebuffer device: %d\n", ret);
+ if (fbi->fb.cmap.len)
+ fb_dealloc_cmap(&fbi->fb.cmap);
+ return ret;
ret = device_create_file(&pdev->dev, &dev_attr_contrast);
@@ -414,25 +394,11 @@ static int wm8505fb_probe(struct platform_device *pdev)
fbi->fb.fix.smem_start + fbi->fb.fix.smem_len - 1);
return 0;
-failed_free_cmap:
- if (fbi->fb.cmap.len)
- fb_dealloc_cmap(&fbi->fb.cmap);
-failed_free_io:
- iounmap(fbi->regbase);
-failed_free_res:
- release_mem_region(res->start, resource_size(res));
-failed_fbi:
- platform_set_drvdata(pdev, NULL);
- kfree(fbi);
-failed:
- return ret;
static int wm8505fb_remove(struct platform_device *pdev)
struct wm8505fb_info *fbi = platform_get_drvdata(pdev);
- struct resource *res;
device_remove_file(&pdev->dev, &dev_attr_contrast);
@@ -443,13 +409,6 @@ static int wm8505fb_remove(struct platform_device *pdev)
- res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- kfree(fbi);
return 0;
