jffs2: drop null test before destroy functions
Author: Julia Lawall <julia.lawall@lip6.fr>
Remove unneeded NULL test.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@@ expression x; @@
-if (x != NULL)
\(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x);
Signed-off-by: Julia Lawall
Signed-off-by: Brian Norris
fs/jffs2/malloc.c | 27 +++++++++------------------
1 file changed, 9 insertions(+), 18 deletions(-)
diff --git a/fs/jffs2/malloc.c b/fs/jffs2/malloc.c
index b8fd651..ce11897 100644
--- a/fs/jffs2/malloc.c
+++ b/fs/jffs2/malloc.c
@@ -97,25 +97,16 @@ int __init jffs2_create_slab_caches(void)
void jffs2_destroy_slab_caches(void)
- if(full_dnode_slab)
- kmem_cache_destroy(full_dnode_slab);
- if(raw_dirent_slab)
- kmem_cache_destroy(raw_dirent_slab);
- if(raw_inode_slab)
- kmem_cache_destroy(raw_inode_slab);
- if(tmp_dnode_info_slab)
- kmem_cache_destroy(tmp_dnode_info_slab);
- if(raw_node_ref_slab)
- kmem_cache_destroy(raw_node_ref_slab);
- if(node_frag_slab)
- kmem_cache_destroy(node_frag_slab);
- if(inode_cache_slab)
- kmem_cache_destroy(inode_cache_slab);
+ kmem_cache_destroy(full_dnode_slab);
+ kmem_cache_destroy(raw_dirent_slab);
+ kmem_cache_destroy(raw_inode_slab);
+ kmem_cache_destroy(tmp_dnode_info_slab);
+ kmem_cache_destroy(raw_node_ref_slab);
+ kmem_cache_destroy(node_frag_slab);
+ kmem_cache_destroy(inode_cache_slab);
#ifdef CONFIG_JFFS2_FS_XATTR
- if (xattr_datum_cache)
- kmem_cache_destroy(xattr_datum_cache);
- if (xattr_ref_cache)
- kmem_cache_destroy(xattr_ref_cache);
+ kmem_cache_destroy(xattr_datum_cache);
+ kmem_cache_destroy(xattr_ref_cache);
#endif
#endif
