dccp: drop null test before destroy functions
Author: Julia Lawall <julia.lawall@lip6.fr>
Remove unneeded NULL test.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x;
-if (x != NULL)
\(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x);
expression x;
-if (x != NULL) {
x = NULL;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
net/dccp/ackvec.c | 12 ++++--------
net/dccp/ccid.c | 3 +--
2 files changed, 5 insertions(+), 10 deletions(-)
diff --git a/net/dccp/ackvec.c b/net/dccp/ackvec.c
index bd9e718..3de0d03 100644
--- a/net/dccp/ackvec.c
+++ b/net/dccp/ackvec.c
@@ -398,12 +398,8 @@ out_err:
void dccp_ackvec_exit(void)
- if (dccp_ackvec_slab != NULL) {
- kmem_cache_destroy(dccp_ackvec_slab);
- dccp_ackvec_slab = NULL;
- if (dccp_ackvec_record_slab != NULL) {
- kmem_cache_destroy(dccp_ackvec_record_slab);
- dccp_ackvec_record_slab = NULL;
+ kmem_cache_destroy(dccp_ackvec_slab);
+ dccp_ackvec_slab = NULL;
+ kmem_cache_destroy(dccp_ackvec_record_slab);
+ dccp_ackvec_record_slab = NULL;
diff --git a/net/dccp/ccid.c b/net/dccp/ccid.c
index 8349897..90f77d0 100644
--- a/net/dccp/ccid.c
+++ b/net/dccp/ccid.c
@@ -95,8 +95,7 @@ static struct kmem_cache *ccid_kmem_cache_create(int obj_size, char *slab_name_f
static void ccid_kmem_cache_destroy(struct kmem_cache *slab)
- if (slab != NULL)
- kmem_cache_destroy(slab);
+ kmem_cache_destroy(slab);
static int __init ccid_activate(struct ccid_operations *ccid_ops) |
- if (slab != NULL)
