ix86/mid/thermal: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Signed-off-by: Matthew Garrett
 drivers/platform/x86/intel_mid_thermal.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/platform/x86/intel_mid_thermal.c b/drivers/platform/x86/intel_mid_thermal.c
index 93fab8b..ab7860a 100644
--- a/drivers/platform/x86/intel_mid_thermal.c
+++ b/drivers/platform/x86/intel_mid_thermal.c
@@ -481,7 +481,8 @@ static int mid_thermal_probe(struct platform_device *pdev)
 	int i;
 	struct platform_info *pinfo;
-	pinfo = kzalloc(sizeof(struct platform_info), GFP_KERNEL);
+	pinfo = devm_kzalloc(&pdev->dev, sizeof(struct platform_info),
+			     GFP_KERNEL);
 	if (!pinfo)
 		return -ENOMEM;
@@ -489,7 +490,6 @@ static int mid_thermal_probe(struct platform_device *pdev)
 	ret = mid_initialize_adc(&pdev->dev);
 	if (ret) {
 		dev_err(&pdev->dev, "ADC init failed");
-		kfree(pinfo);
 		return ret;
@@ -520,7 +520,6 @@ err:
 		thermal_zone_device_unregister(pinfo->tzd[i]);
 	configure_adc(0);
-	kfree(pinfo);
 	return ret;
@@ -541,8 +540,6 @@ static int mid_thermal_remove(struct platform_device *pdev)
-	kfree(pinfo);
 	/* Stop the ADC */
 	return configure_adc(0);
BtrLinux
Privacy Overview
