drivers/staging/rtl8712/hal_init.c | 2 +-
drivers/staging/rtl8712/mlme_linux.c | 3 +-
drivers/staging/rtl8712/osdep_service.h | 5 --
drivers/staging/rtl8712/rtl8712_recv.c | 6 +-
drivers/staging/rtl8712/rtl871x_cmd.c | 123 +++++++++++---------------
drivers/staging/rtl8712/rtl871x_io.c | 11 +--
drivers/staging/rtl8712/rtl871x_ioctl_linux.c | 35 +++-----
drivers/staging/rtl8712/rtl871x_mlme.c | 17 ++--
drivers/staging/rtl8712/rtl871x_mp.c | 10 +--
drivers/staging/rtl8712/rtl871x_recv.c | 6 +-
drivers/staging/rtl8712/rtl871x_sta_mgt.c | 4 +-
drivers/staging/rtl8712/rtl871x_xmit.c | 16 ++--
drivers/staging/rtl8712/usb_ops_linux.c | 2 +-
13 files changed, 102 insertions(+), 138 deletions(-)
diff --git a/drivers/staging/rtl8712/hal_init.c b/drivers/staging/rtl8712/hal_init.c
index d801c5a..36de7e4 100644
--- a/drivers/staging/rtl8712/hal_init.c
+++ b/drivers/staging/rtl8712/hal_init.c
@@ -183,7 +183,7 @@ static u8 rtl8712_dl_fw(struct _adapter *padapter)
maxlen = (fwhdr.img_IMEM_size > fwhdr.img_SRAM_size) ?
fwhdr.img_IMEM_size : fwhdr.img_SRAM_size;
maxlen += txdscp_sz;
- ptmpchar = _malloc(maxlen + FWBUFF_ALIGN_SZ);
+ ptmpchar = kmalloc(maxlen + FWBUFF_ALIGN_SZ, GFP_ATOMIC);
if (ptmpchar == NULL)
return ret;
diff --git a/drivers/staging/rtl8712/mlme_linux.c b/drivers/staging/rtl8712/mlme_linux.c
index f569a70..377efb8 100644
--- a/drivers/staging/rtl8712/mlme_linux.c
+++ b/drivers/staging/rtl8712/mlme_linux.c
@@ -147,10 +147,9 @@ void r8712_report_sec_ie(struct _adapter *adapter, u8 authmode, u8 *sec_ie)
buff = NULL;
if (authmode == _WPA_IE_ID_) {
- buff = _malloc(IW_CUSTOM_MAX);
+ buff = kzalloc(IW_CUSTOM_MAX, GFP_ATOMIC);
if (buff == NULL)
return;
- memset(buff, 0, IW_CUSTOM_MAX);
p = buff;
p += sprintf(p, "ASSOCINFO(ReqIEs=");
len = sec_ie[1] + 2;
diff --git a/drivers/staging/rtl8712/osdep_service.h b/drivers/staging/rtl8712/osdep_service.h
index 566235a..09e1561 100644
--- a/drivers/staging/rtl8712/osdep_service.h
+++ b/drivers/staging/rtl8712/osdep_service.h
@@ -168,11 +168,6 @@ static inline void sleep_schedulable(int ms)
return;
-static inline u8 *_malloc(u32 sz)
- return kmalloc(sz, GFP_ATOMIC);
static inline unsigned char _cancel_timer_ex(struct timer_list *ptimer)
return del_timer(ptimer);
diff --git a/drivers/staging/rtl8712/rtl8712_recv.c b/drivers/staging/rtl8712/rtl8712_recv.c
index 667398a..1f70017 100644
--- a/drivers/staging/rtl8712/rtl8712_recv.c
+++ b/drivers/staging/rtl8712/rtl8712_recv.c
@@ -58,12 +58,10 @@ int r8712_init_recv_priv(struct recv_priv *precvpriv, struct _adapter *padapter)
/*init recv_buf*/
_init_queue(&precvpriv->free_recv_buf_queue);
- precvpriv->pallocated_recv_buf = _malloc(NR_RECVBUFF *
- sizeof(struct recv_buf) + 4);
+ precvpriv->pallocated_recv_buf = kzalloc(NR_RECVBUFF * sizeof(struct recv_buf) + 4,
+ GFP_ATOMIC);
if (precvpriv->pallocated_recv_buf == NULL)
return _FAIL;
- memset(precvpriv->pallocated_recv_buf, 0, NR_RECVBUFF *
precvpriv->precv_buf = precvpriv->pallocated_recv_buf + 4 -
((addr_t) (precvpriv->pallocated_recv_buf) & 3);
precvbuf = (struct recv_buf *)precvpriv->precv_buf;
diff --git a/drivers/staging/rtl8712/rtl871x_cmd.c b/drivers/staging/rtl8712/rtl871x_cmd.c
index a67185d..6a3cecc 100644
--- a/drivers/staging/rtl8712/rtl871x_cmd.c
+++ b/drivers/staging/rtl8712/rtl871x_cmd.c
@@ -64,13 +64,14 @@ static sint _init_cmd_priv(struct cmd_priv *pcmdpriv)
/* allocate DMA-able/Non-Page memory for cmd_buf and rsp_buf */
pcmdpriv->cmd_seq = 1;
- pcmdpriv->cmd_allocated_buf = _malloc(MAX_CMDSZ + CMDBUFF_ALIGN_SZ);
+ pcmdpriv->cmd_allocated_buf = kmalloc(MAX_CMDSZ + CMDBUFF_ALIGN_SZ,
+ GFP_ATOMIC);
if (pcmdpriv->cmd_allocated_buf == NULL)
return _FAIL;
pcmdpriv->cmd_buf = pcmdpriv->cmd_allocated_buf + CMDBUFF_ALIGN_SZ -
((addr_t)(pcmdpriv->cmd_allocated_buf) &
(CMDBUFF_ALIGN_SZ-1));
- pcmdpriv->rsp_allocated_buf = _malloc(MAX_RSPSZ + 4);
+ pcmdpriv->rsp_allocated_buf = kmalloc(MAX_RSPSZ + 4, GFP_ATOMIC);
if (pcmdpriv->rsp_allocated_buf == NULL)
return _FAIL;
pcmdpriv->rsp_buf = pcmdpriv->rsp_allocated_buf + 4 -
@@ -85,7 +86,7 @@ static sint _init_evt_priv(struct evt_priv *pevtpriv)
pevtpriv->event_seq = 0;
- pevtpriv->evt_allocated_buf = _malloc(MAX_EVTSZ + 4);
+ pevtpriv->evt_allocated_buf = kmalloc(MAX_EVTSZ + 4, GFP_ATOMIC);
if (pevtpriv->evt_allocated_buf == NULL)
return _FAIL;
@@ -226,11 +227,10 @@ u8 r8712_sitesurvey_cmd(struct _adapter *padapter,
struct cmd_priv *pcmdpriv = &padapter->cmdpriv;
struct mlme_priv *pmlmepriv = &padapter->mlmepriv;
- ph2c = (struct cmd_obj *)_malloc(sizeof(struct cmd_obj));
+ ph2c = kmalloc(sizeof(struct cmd_obj), GFP_ATOMIC);
if (ph2c == NULL)
return _FAIL;
- psurveyPara = (struct sitesurvey_parm *)_malloc(
- sizeof(struct sitesurvey_parm));
+ psurveyPara = kmalloc(sizeof(struct sitesurvey_parm), GFP_ATOMIC);
if (psurveyPara == NULL) {
kfree((unsigned char *) ph2c);
return _FAIL;
@@ -259,11 +259,11 @@ u8 r8712_setdatarate_cmd(struct _adapter *padapter, u8 *rateset)
struct setdatarate_parm *pbsetdataratepara;
if (ph2c == NULL)
return _FAIL;
- pbsetdataratepara = (struct setdatarate_parm *)_malloc(
- sizeof(struct setdatarate_parm));
+ pbsetdataratepara = kmalloc(sizeof(struct setdatarate_parm),
+ GFP_ATOMIC);
if (pbsetdataratepara == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -282,11 +282,11 @@ u8 r8712_set_chplan_cmd(struct _adapter *padapter, int chplan)
struct SetChannelPlan_param *psetchplanpara;
if (ph2c == NULL)
return _FAIL;
- psetchplanpara = (struct SetChannelPlan_param *)
- _malloc(sizeof(struct SetChannelPlan_param));
+ psetchplanpara = kmalloc(sizeof(struct SetChannelPlan_param),
+ GFP_ATOMIC);
if (psetchplanpara == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -304,11 +304,11 @@ u8 r8712_setbasicrate_cmd(struct _adapter *padapter, u8 *rateset)
struct setbasicrate_parm *pssetbasicratepara;
if (ph2c == NULL)
return _FAIL;
- pssetbasicratepara = (struct setbasicrate_parm *)_malloc(
- sizeof(struct setbasicrate_parm));
+ pssetbasicratepara = kmalloc(sizeof(struct setbasicrate_parm),
+ GFP_ATOMIC);
if (pssetbasicratepara == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -327,11 +327,10 @@ u8 r8712_setptm_cmd(struct _adapter *padapter, u8 type)
struct writePTM_parm *pwriteptmparm;
if (ph2c == NULL)
return _FAIL;
- pwriteptmparm = (struct writePTM_parm *)
- _malloc(sizeof(struct writePTM_parm));
+ pwriteptmparm = kmalloc(sizeof(struct writePTM_parm), GFP_ATOMIC);
if (pwriteptmparm == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -348,11 +347,10 @@ u8 r8712_setfwdig_cmd(struct _adapter *padapter, u8 type)
if (ph2c == NULL)
return _FAIL;
- _malloc(sizeof(struct setdig_parm));
+ pwriteptmparm = kmalloc(sizeof(struct setdig_parm), GFP_ATOMIC);
kfree((u8 *) ph2c);
return _FAIL;
@@ -369,11 +367,10 @@ u8 r8712_setfwra_cmd(struct _adapter *padapter, u8 type)
if (ph2c == NULL)
return _FAIL;
- _malloc(sizeof(struct setra_parm));
+ pwriteptmparm = kmalloc(sizeof(struct setra_parm), GFP_ATOMIC);
kfree((u8 *) ph2c);
return _FAIL;
@@ -390,11 +387,10 @@ u8 r8712_setrfreg_cmd(struct _adapter *padapter, u8 offset, u32 val)
struct writeRF_parm *pwriterfparm;
if (ph2c == NULL)
return _FAIL;
- pwriterfparm = (struct writeRF_parm *)_malloc(
- sizeof(struct writeRF_parm));
+ pwriterfparm = kmalloc(sizeof(struct writeRF_parm), GFP_ATOMIC);
if (pwriterfparm == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -412,10 +408,10 @@ u8 r8712_getrfreg_cmd(struct _adapter *padapter, u8 offset, u8 *pval)
struct readRF_parm *prdrfparm;
if (ph2c == NULL)
return _FAIL;
- prdrfparm = (struct readRF_parm *)_malloc(sizeof(struct readRF_parm));
+ prdrfparm = kmalloc(sizeof(struct readRF_parm), GFP_ATOMIC);
if (prdrfparm == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -456,7 +452,7 @@ u8 r8712_createbss_cmd(struct _adapter *padapter)
&padapter->registrypriv.dev_network;
padapter->ledpriv.LedControlHandler(padapter, LED_CTL_START_TO_LINK);
- pcmd = (struct cmd_obj *)_malloc(sizeof(struct cmd_obj));
+ pcmd = kmalloc(sizeof(struct cmd_obj), GFP_ATOMIC);
if (pcmd == NULL)
return _FAIL;
_init_listhead(&pcmd->list);
@@ -490,7 +486,7 @@ u8 r8712_joinbss_cmd(struct _adapter *padapter, struct wlan_network *pnetwork)
network.InfrastructureMode;
if (pcmd == NULL)
return _FAIL;
t_len = sizeof(u32) + 6 * sizeof(unsigned char) + 2 +
@@ -628,11 +624,10 @@ u8 r8712_disassoc_cmd(struct _adapter *padapter) /* for sta_mode */
struct disconnect_parm *pdisconnect;
- pdisconnect_cmd = (struct cmd_obj *)_malloc(sizeof(struct cmd_obj));
+ pdisconnect_cmd = kmalloc(sizeof(struct cmd_obj), GFP_ATOMIC);
if (pdisconnect_cmd == NULL)
return _FAIL;
- pdisconnect = (struct disconnect_parm *)_malloc(
- sizeof(struct disconnect_parm));
+ pdisconnect = kmalloc(sizeof(struct disconnect_parm), GFP_ATOMIC);
if (pdisconnect == NULL) {
kfree((u8 *)pdisconnect_cmd);
return _FAIL;
@@ -651,11 +646,10 @@ u8 r8712_setopmode_cmd(struct _adapter *padapter,
if (ph2c == NULL)
return _FAIL;
- psetop = (struct setopmode_parm *)_malloc(
- sizeof(struct setopmode_parm));
+ psetop = kmalloc(sizeof(struct setopmode_parm), GFP_ATOMIC);
if (psetop == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -676,17 +670,15 @@ u8 r8712_setstakey_cmd(struct _adapter *padapter, u8 *psta, u8 unicast_key)
struct security_priv *psecuritypriv = &padapter->securitypriv;
struct sta_info *sta = (struct sta_info *)psta;
if (ph2c == NULL)
return _FAIL;
- psetstakey_para = (struct set_stakey_parm *)_malloc(
- sizeof(struct set_stakey_parm));
+ psetstakey_para = kmalloc(sizeof(struct set_stakey_parm), GFP_ATOMIC);
if (psetstakey_para == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
- psetstakey_rsp = (struct set_stakey_rsp *)_malloc(
- sizeof(struct set_stakey_rsp));
+ psetstakey_rsp = kmalloc(sizeof(struct set_stakey_rsp), GFP_ATOMIC);
if (psetstakey_rsp == NULL) {
kfree((u8 *) ph2c);
kfree((u8 *) psetstakey_para);
@@ -718,11 +710,10 @@ u8 r8712_setrfintfs_cmd(struct _adapter *padapter, u8 mode)
struct setrfintfs_parm *psetrfintfsparm;
if (ph2c == NULL)
return _FAIL;
- psetrfintfsparm = (struct setrfintfs_parm *)_malloc(
- sizeof(struct setrfintfs_parm));
+ psetrfintfsparm = kmalloc(sizeof(struct setrfintfs_parm), GFP_ATOMIC);
if (psetrfintfsparm == NULL) {
return _FAIL;
@@ -741,11 +732,10 @@ u8 r8712_setrttbl_cmd(struct _adapter *padapter,
struct setratable_parm *psetrttblparm;
if (ph2c == NULL)
return _FAIL;
- psetrttblparm = (struct setratable_parm *)_malloc(
- sizeof(struct setratable_parm));
+ psetrttblparm = kmalloc(sizeof(struct setratable_parm), GFP_ATOMIC);
if (psetrttblparm == NULL) {
kfree((unsigned char *)ph2c);
return _FAIL;
@@ -763,11 +753,10 @@ u8 r8712_gettssi_cmd(struct _adapter *padapter, u8 offset, u8 *pval)
struct cmd_obj *ph2c;
struct readTSSI_parm *prdtssiparm;
if (ph2c == NULL)
return _FAIL;
- prdtssiparm = (struct readTSSI_parm *)
- _malloc(sizeof(struct readTSSI_parm));
+ prdtssiparm = kmalloc(sizeof(struct readTSSI_parm), GFP_ATOMIC);
if (prdtssiparm == NULL) {
return _FAIL;
@@ -790,11 +779,11 @@ u8 r8712_setMacAddr_cmd(struct _adapter *padapter, u8 *mac_addr)
struct SetMacAddr_param *psetMacAddr_para;
if (ph2c == NULL)
return _FAIL;
- psetMacAddr_para = (struct SetMacAddr_param *)_malloc(
- sizeof(struct SetMacAddr_param));
+ psetMacAddr_para = kmalloc(sizeof(struct SetMacAddr_param),
+ GFP_ATOMIC);
if (psetMacAddr_para == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
@@ -813,17 +802,17 @@ u8 r8712_setassocsta_cmd(struct _adapter *padapter, u8 *mac_addr)
struct set_assocsta_parm *psetassocsta_para;
struct set_assocsta_rsp *psetassocsta_rsp = NULL;
if (ph2c == NULL)
return _FAIL;
- psetassocsta_para = (struct set_assocsta_parm *)
- _malloc(sizeof(struct set_assocsta_parm));
+ psetassocsta_para = kmalloc(sizeof(struct set_assocsta_parm),
+ GFP_ATOMIC);
if (psetassocsta_para == NULL) {
kfree((u8 *) ph2c);
return _FAIL;
- psetassocsta_rsp = (struct set_assocsta_rsp *)_malloc(
- sizeof(struct set_assocsta_rsp));
+ psetassocsta_rsp = kmalloc(sizeof(struct set_assocsta_rsp),
+ GFP_ATOMIC);
if (psetassocsta_rsp == NULL) {
kfree((u8 *)ph2c);
kfree((u8 *)psetassocsta_para);
@@ -843,11 +832,10 @@ u8 r8712_addbareq_cmd(struct _adapter *padapter, u8 tid)
struct addBaReq_parm *paddbareq_parm;
if (ph2c == NULL)
return _FAIL;
- paddbareq_parm = (struct addBaReq_parm *)_malloc(
- sizeof(struct addBaReq_parm));
+ paddbareq_parm = kmalloc(sizeof(struct addBaReq_parm), GFP_ATOMIC);
if (paddbareq_parm == NULL) {
return _FAIL;
@@ -865,11 +853,10 @@ u8 r8712_wdg_wk_cmd(struct _adapter *padapter)
struct drvint_cmd_parm *pdrvintcmd_param;
if (ph2c == NULL)
return _FAIL;
- pdrvintcmd_param = (struct drvint_cmd_parm *)_malloc(
- sizeof(struct drvint_cmd_parm));
+ pdrvintcmd_param = kmalloc(sizeof(struct drvint_cmd_parm), GFP_ATOMIC);
if (pdrvintcmd_param == NULL) {
return _FAIL;
@@ -1040,16 +1027,14 @@ u8 r8712_disconnectCtrlEx_cmd(struct _adapter *adapter, u32 enableDrvCtrl,
struct DisconnectCtrlEx_param *param;
struct cmd_priv *pcmdpriv = &adapter->cmdpriv;
if (ph2c == NULL)
return _FAIL;
- param = (struct DisconnectCtrlEx_param *)
- _malloc(sizeof(struct DisconnectCtrlEx_param));
+ param = kzalloc(sizeof(struct DisconnectCtrlEx_param), GFP_ATOMIC);
if (param == NULL) {
return _FAIL;
- memset(param, 0, sizeof(struct DisconnectCtrlEx_param));
param->EnableDrvCtrl = (unsigned char)enableDrvCtrl;
param->TryPktCnt = (unsigned char)tryPktCnt;
diff --git a/drivers/staging/rtl8712/rtl871x_io.c b/drivers/staging/rtl8712/rtl871x_io.c
index abc1c97..37a841a 100644
--- a/drivers/staging/rtl8712/rtl871x_io.c
+++ b/drivers/staging/rtl8712/rtl871x_io.c
@@ -60,8 +60,8 @@ static uint _init_intf_hdl(struct _adapter *padapter,
set_intf_funs = &(r8712_usb_set_intf_funs);
set_intf_ops = &r8712_usb_set_intf_ops;
init_intf_priv = &r8712_usb_init_intf_priv;
- pintf_priv = pintf_hdl->pintfpriv = (struct intf_priv *)
- _malloc(sizeof(struct intf_priv));
+ pintf_priv = pintf_hdl->pintfpriv = kmalloc(sizeof(struct intf_priv),
+ GFP_ATOMIC);
if (pintf_priv == NULL)
goto _init_intf_hdl_fail;
pintf_hdl->adapter = (u8 *)padapter;
@@ -112,15 +112,16 @@ uint r8712_alloc_io_queue(struct _adapter *adapter)
struct io_queue *pio_queue;
struct io_req *pio_req;
- pio_queue = (struct io_queue *)_malloc(sizeof(struct io_queue));
+ pio_queue = kmalloc(sizeof(struct io_queue), GFP_ATOMIC);
if (pio_queue == NULL)
goto alloc_io_queue_fail;
_init_listhead(&pio_queue->free_ioreqs);
_init_listhead(&pio_queue->processing);
_init_listhead(&pio_queue->pending);
spin_lock_init(&pio_queue->lock);
- pio_queue->pallocated_free_ioreqs_buf = (u8 *)_malloc(NUM_IOREQ *
- (sizeof(struct io_req)) + 4);
+ pio_queue->pallocated_free_ioreqs_buf = kmalloc(NUM_IOREQ *
+ (sizeof(struct io_req)) + 4,
+ GFP_ATOMIC);
if ((pio_queue->pallocated_free_ioreqs_buf) == NULL)
memset(pio_queue->pallocated_free_ioreqs_buf, 0,
diff --git a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
index 1eca992..e147c4b 100644
--- a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
+++ b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
@@ -424,10 +424,9 @@ static int wpa_set_encryption(struct net_device *dev, struct ieee_param *param,
wep_key_idx = 0;
if (wep_key_len > 0) {
wep_key_len = wep_key_len <= 5 ? 5 : 13;
- pwep = (struct NDIS_802_11_WEP *)_malloc((u32)
- (wep_key_len +
- FIELD_OFFSET(struct NDIS_802_11_WEP,
- KeyMaterial)));
+ pwep = kmalloc((u32)(wep_key_len +
+ FIELD_OFFSET(struct NDIS_802_11_WEP, KeyMaterial)),
+ GFP_ATOMIC);
if (pwep == NULL)
return -ENOMEM;
memset(pwep, 0, sizeof(struct NDIS_802_11_WEP));
@@ -518,10 +517,9 @@ static int r871x_set_wpa_ie(struct _adapter *padapter, char *pie,
if ((ielen > MAX_WPA_IE_LEN) || (pie == NULL))
return -EINVAL;
if (ielen) {
- buf = _malloc(ielen);
+ buf = kmemdup(pie, ielen, GFP_ATOMIC);
if (buf == NULL)
return -ENOMEM;
- memcpy(buf, pie , ielen);
pos = buf;
if (ielen < RSN_HEADER_LEN) {
ret = -EINVAL;
@@ -959,13 +957,9 @@ static int r871x_wx_set_priv(struct net_device *dev,
struct iw_point *dwrq = (struct iw_point *)awrq;
len = dwrq->length;
- ext = _malloc(len);
- if (!ext)
- return -ENOMEM;
- if (copy_from_user(ext, dwrq->pointer, len)) {
- kfree(ext);
- return -EFAULT;
+ ext = memdup_user(dwrq->pointer, len);
+ if (IS_ERR(ext))
+ return PTR_ERR(ext);
if (0 == strcasecmp(ext, "RSSI")) {
/*Return received signal strength indicator in -db for */
@@ -1819,10 +1813,9 @@ static int r871x_wx_set_enc_ext(struct net_device *dev,
param_len = sizeof(struct ieee_param) + pext->key_len;
- param = (struct ieee_param *)_malloc(param_len);
+ param = kzalloc(param_len, GFP_ATOMIC);
if (param == NULL)
return -ENOMEM;
- memset(param, 0, param_len);
param->cmd = IEEE_CMD_SET_ENCRYPTION;
memset(param->sta_addr, 0xff, ETH_ALEN);
@@ -1922,7 +1915,7 @@ static int r871x_mp_ioctl_hdl(struct net_device *dev,
bset = (u8)(p->flags & 0xFFFF);
len = p->length;
pparmbuf = NULL;
- pparmbuf = (u8 *)_malloc(len);
+ pparmbuf = kmalloc(len, GFP_ATOMIC);
if (pparmbuf == NULL) {
ret = -ENOMEM;
goto _r871x_mp_ioctl_hdl_exit;
@@ -2195,13 +2188,9 @@ static int wpa_supplicant_ioctl(struct net_device *dev, struct iw_point *p)
if (p->length < sizeof(struct ieee_param) || !p->pointer)
return -EINVAL;
- param = (struct ieee_param *)_malloc(p->length);
- if (param == NULL)
- return -ENOMEM;
- if (copy_from_user(param, p->pointer, p->length)) {
- kfree((u8 *)param);
- return -EFAULT;
+ param = memdup_user(p->pointer, p->length);
+ if (IS_ERR(param))
+ return PTR_ERR(param);
switch (param->cmd) {
case IEEE_CMD_SET_WPA_PARAM:
ret = wpa_set_param(dev, param->u.wpa_param.name,
diff --git a/drivers/staging/rtl8712/rtl871x_mlme.c b/drivers/staging/rtl8712/rtl871x_mlme.c
index f8f651a..02339e1 100644
--- a/drivers/staging/rtl8712/rtl871x_mlme.c
+++ b/drivers/staging/rtl8712/rtl871x_mlme.c
@@ -62,7 +62,8 @@ static sint _init_mlme_priv(struct _adapter *padapter)
_init_queue(&(pmlmepriv->scanned_queue));
set_scanned_network_val(pmlmepriv, 0);
memset(&pmlmepriv->assoc_ssid, 0, sizeof(struct ndis_802_11_ssid));
- pbuf = _malloc(MAX_BSS_CNT * (sizeof(struct wlan_network)));
+ pbuf = kmalloc(MAX_BSS_CNT * (sizeof(struct wlan_network)),
+ GFP_ATOMIC);
if (pbuf == NULL)
return _FAIL;
pmlmepriv->free_bss_buf = pbuf;
@@ -725,8 +726,7 @@ void r8712_joinbss_event_callback(struct _adapter *adapter, u8 *pbuf)
struct wlan_network *pnetwork;
if (sizeof(struct list_head) == 4 * sizeof(u32)) {
- pnetwork = (struct wlan_network *)
- _malloc(sizeof(struct wlan_network));
+ pnetwork = kmalloc(sizeof(struct wlan_network), GFP_ATOMIC);
memcpy((u8 *)pnetwork+16, (u8 *)pbuf + 8,
sizeof(struct wlan_network) - 16);
} else
@@ -1212,17 +1212,15 @@ sint r8712_set_auth(struct _adapter *adapter,
struct cmd_obj *pcmd;
struct setauth_parm *psetauthparm;
if (pcmd == NULL)
return _FAIL;
- psetauthparm = (struct setauth_parm *)_malloc(
- sizeof(struct setauth_parm));
+ psetauthparm = kzalloc(sizeof(struct setauth_parm), GFP_ATOMIC);
if (psetauthparm == NULL) {
kfree((unsigned char *)pcmd);
return _FAIL;
- memset(psetauthparm, 0, sizeof(struct setauth_parm));
psetauthparm->mode = (u8)psecuritypriv->AuthAlgrthm;
pcmd->cmdcode = _SetAuth_CMD_;
pcmd->parmbuf = (unsigned char *)psetauthparm;
@@ -1244,15 +1242,14 @@ sint r8712_set_key(struct _adapter *adapter,
u8 keylen;
sint ret = _SUCCESS;
if (pcmd == NULL)
return _FAIL;
- psetkeyparm = (struct setkey_parm *)_malloc(sizeof(struct setkey_parm));
+ psetkeyparm = kzalloc(sizeof(struct setkey_parm), GFP_ATOMIC);
if (psetkeyparm == NULL) {
ret = _FAIL;
goto err_free_cmd;
- memset(psetkeyparm, 0, sizeof(struct setkey_parm));
if (psecuritypriv->AuthAlgrthm == 2) { /* 802.1X */
psetkeyparm->algorithm =
(u8)psecuritypriv->XGrpPrivacy;
diff --git a/drivers/staging/rtl8712/rtl871x_mp.c b/drivers/staging/rtl8712/rtl871x_mp.c
index 5fd60cd..389062f 100644
--- a/drivers/staging/rtl8712/rtl871x_mp.c
+++ b/drivers/staging/rtl8712/rtl871x_mp.c
@@ -53,8 +53,9 @@ static int init_mp_priv(struct mp_priv *pmp_priv)
_init_mp_priv_(pmp_priv);
_init_queue(&pmp_priv->free_mp_xmitqueue);
pmp_priv->pallocated_mp_xmitframe_buf = NULL;
- pmp_priv->pallocated_mp_xmitframe_buf = _malloc(NR_MP_XMITFRAME *
- sizeof(struct mp_xmit_frame) + 4);
+ pmp_priv->pallocated_mp_xmitframe_buf = kmalloc(NR_MP_XMITFRAME *
+ sizeof(struct mp_xmit_frame) + 4,
+ GFP_ATOMIC);
if (pmp_priv->pallocated_mp_xmitframe_buf == NULL) {
res = _FAIL;
goto _exit_init_mp_priv;
@@ -280,11 +281,10 @@ void r8712_SetChannel(struct _adapter *pAdapter)
struct SetChannel_parm *pparm = NULL;
u16 code = GEN_CMD_CODE(_SetChannel);
if (pcmd == NULL)
return;
- pparm = (struct SetChannel_parm *)_malloc(sizeof(struct
- SetChannel_parm));
+ pparm = kmalloc(sizeof(struct SetChannel_parm), GFP_ATOMIC);
if (pparm == NULL) {
kfree(pcmd);
return;
diff --git a/drivers/staging/rtl8712/rtl871x_recv.c b/drivers/staging/rtl8712/rtl871x_recv.c
index 4ac4a1b..eb77587 100644
--- a/drivers/staging/rtl8712/rtl871x_recv.c
+++ b/drivers/staging/rtl8712/rtl871x_recv.c
@@ -72,9 +72,9 @@ sint _r8712_init_recv_priv(struct recv_priv *precvpriv,
_init_queue(&precvpriv->recv_pending_queue);
precvpriv->adapter = padapter;
precvpriv->free_recvframe_cnt = NR_RECVFRAME;
- precvpriv->pallocated_frame_buf = _malloc(NR_RECVFRAME *
- sizeof(union recv_frame) +
- RXFRAME_ALIGN_SZ);
+ precvpriv->pallocated_frame_buf = kmalloc(NR_RECVFRAME *
+ sizeof(union recv_frame) + RXFRAME_ALIGN_SZ,
+ GFP_ATOMIC);
if (precvpriv->pallocated_frame_buf == NULL)
return _FAIL;
kmemleak_not_leak(precvpriv->pallocated_frame_buf);
diff --git a/drivers/staging/rtl8712/rtl871x_sta_mgt.c b/drivers/staging/rtl8712/rtl871x_sta_mgt.c
index 8db6849..6c64984 100644
--- a/drivers/staging/rtl8712/rtl871x_sta_mgt.c
+++ b/drivers/staging/rtl8712/rtl871x_sta_mgt.c
@@ -51,8 +51,8 @@ u32 _r8712_init_sta_priv(struct sta_priv *pstapriv)
struct sta_info *psta;
s32 i;
- pstapriv->pallocated_stainfo_buf = _malloc(sizeof(struct sta_info) *
- NUM_STA + 4);
+ pstapriv->pallocated_stainfo_buf = kmalloc(sizeof(struct sta_info) *
+ NUM_STA + 4, GFP_ATOMIC);
if (pstapriv->pallocated_stainfo_buf == NULL)
return _FAIL;
pstapriv->pstainfo_buf = pstapriv->pallocated_stainfo_buf + 4 -
diff --git a/drivers/staging/rtl8712/rtl871x_xmit.c b/drivers/staging/rtl8712/rtl871x_xmit.c
index 78f570b..230681a 100644
--- a/drivers/staging/rtl8712/rtl871x_xmit.c
+++ b/drivers/staging/rtl8712/rtl871x_xmit.c
@@ -87,8 +87,8 @@ sint _r8712_init_xmit_priv(struct xmit_priv *pxmitpriv,
and initialize free_xmit_frame below.
Please also apply free_txobj to link_up all the xmit_frames...
- pxmitpriv->pallocated_frame_buf = _malloc(NR_XMITFRAME *
- sizeof(struct xmit_frame) + 4);
+ pxmitpriv->pallocated_frame_buf = kmalloc(NR_XMITFRAME * sizeof(struct xmit_frame) + 4,
+ GFP_ATOMIC);
if (pxmitpriv->pallocated_frame_buf == NULL) {
pxmitpriv->pxmit_frame_buf = NULL;
return _FAIL;
@@ -126,8 +126,8 @@ sint _r8712_init_xmit_priv(struct xmit_priv *pxmitpriv,
/*init xmit_buf*/
_init_queue(&pxmitpriv->free_xmitbuf_queue);
_init_queue(&pxmitpriv->pending_xmitbuf_queue);
- pxmitpriv->pallocated_xmitbuf = _malloc(NR_XMITBUFF *
- sizeof(struct xmit_buf) + 4);
+ pxmitpriv->pallocated_xmitbuf = kmalloc(NR_XMITBUFF * sizeof(struct xmit_buf) + 4,
+ GFP_ATOMIC);
if (pxmitpriv->pallocated_xmitbuf == NULL)
return _FAIL;
pxmitpriv->pxmitbuf = pxmitpriv->pallocated_xmitbuf + 4 -
@@ -135,8 +135,8 @@ sint _r8712_init_xmit_priv(struct xmit_priv *pxmitpriv,
pxmitbuf = (struct xmit_buf *)pxmitpriv->pxmitbuf;
for (i = 0; i < NR_XMITBUFF; i++) {
_init_listhead(&pxmitbuf->list);
- pxmitbuf->pallocated_buf = _malloc(MAX_XMITBUF_SZ +
- XMITBUF_ALIGN_SZ);
+ pxmitbuf->pallocated_buf = kmalloc(MAX_XMITBUF_SZ + XMITBUF_ALIGN_SZ,
+ GFP_ATOMIC);
if (pxmitbuf->pallocated_buf == NULL)
return _FAIL;
pxmitbuf->pbuf = pxmitbuf->pallocated_buf + XMITBUF_ALIGN_SZ -
@@ -955,8 +955,8 @@ static void alloc_hwxmits(struct _adapter *padapter)
struct xmit_priv *pxmitpriv = &padapter->xmitpriv;
pxmitpriv->hwxmit_entry = HWXMIT_ENTRY;
- pxmitpriv->hwxmits = (struct hw_xmit *)_malloc(sizeof(struct hw_xmit) *
- pxmitpriv->hwxmit_entry);
+ pxmitpriv->hwxmits = kmalloc(sizeof(struct hw_xmit) * pxmitpriv->hwxmit_entry,
+ GFP_ATOMIC);
if (pxmitpriv->hwxmits == NULL)
return;
hwxmits = pxmitpriv->hwxmits;
diff --git a/drivers/staging/rtl8712/usb_ops_linux.c b/drivers/staging/rtl8712/usb_ops_linux.c
index dca398a..064dc10 100644
--- a/drivers/staging/rtl8712/usb_ops_linux.c
+++ b/drivers/staging/rtl8712/usb_ops_linux.c
@@ -495,7 +495,7 @@ int r8712_usbctrl_vendorreq(struct intf_priv *pintfpriv, u8 request, u16 value,
u8 *palloc_buf, *pIo_buf;
- palloc_buf = _malloc((u32) len + 16);
+ palloc_buf = kmalloc((u32)len + 16, GFP_ATOMIC);
if (palloc_buf == NULL) {
dev_err(&udev->dev, "%s: Can't alloc memory for vendor request\n",
__func__); |
