iommu/msm: Deletion of unnecessary checks before clk_disable()
Author: SF Markus Elfring <elfring@users.sourceforge.net>
A semantic patch approach was proposed with the subject
"[PATCH with Coccinelle?] Deletion of unnecessary checks
before specific function calls" on 2014-03-05.
https://lkml.org/lkml/2014/3/5/344
http://article.gmane.org/gmane.comp.version-control.coccinelle/3513/
This patch pattern application was repeated with the help of
the software "Coccinelle 1.0.0-rc22" on the source files for
Linux 3.17.1. An extract of the automatically generated
update suggestions is shown here.
It was determined that the affected source code places call
functions which perform input parameter validation already.
It is therefore not needed that a similar safety check is
repeated at the call site.
Signed-off-by: Markus Elfring
Signed-off-by: Joerg Roedel
 drivers/iommu/msm_iommu.c     | 3 +--
 drivers/iommu/msm_iommu_dev.c | 6 ++----
 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/iommu/msm_iommu.c b/drivers/iommu/msm_iommu.c
index 6e3dcc28..3e4d888 100644
--- a/drivers/iommu/msm_iommu.c
+++ b/drivers/iommu/msm_iommu.c
@@ -73,8 +73,7 @@ fail:
 static void __disable_clocks(struct msm_iommu_drvdata *drvdata)
-	if (drvdata->clk)
-		clk_disable(drvdata->clk);
+	clk_disable(drvdata->clk);
 	clk_disable(drvdata->pclk);
diff --git a/drivers/iommu/msm_iommu_dev.c b/drivers/iommu/msm_iommu_dev.c
index 61def7cb..9574d21 100644
--- a/drivers/iommu/msm_iommu_dev.c
+++ b/drivers/iommu/msm_iommu_dev.c
@@ -224,8 +224,7 @@ static int msm_iommu_probe(struct platform_device *pdev)
 	platform_set_drvdata(pdev, drvdata);
-	if (iommu_clk)
-		clk_disable(iommu_clk);
+	clk_disable(iommu_clk);
 	clk_disable(iommu_pclk);
@@ -323,8 +322,7 @@ static int msm_iommu_ctx_probe(struct platform_device *pdev)
 		SET_NSCFG(drvdata->base, mid, 3);
-	if (drvdata->clk)
 	dev_info(&pdev->dev, "context %s using bank %d\n", c->name, c->num);
BtrLinux
Privacy Overview
