staging: media: omap24xx: Use min_t instead of min
Author: Aybuke Ozdemir <aybuke.147@gmail.com>
This patch focuses on fixing the following warning generated by
checkpatch.pl for the file tcm825x.c:
WARNİNG: min() should probably be min_t(u32, tgt_xclk, TCM825X_XCLK_MAX)
The changes were applied using the following coccinelle rule:
expression e1, e2;
typedef u32;
-tgt_xclk = min(e1, (u32)e2);
+tgt_xclk = min_t(u32, e1, e2);
Signed-off-by: Aybuke Ozdemir
drivers/staging/media/omap24xx/tcm825x.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/media/omap24xx/tcm825x.c b/drivers/staging/media/omap24xx/tcm825x.c
index 9d9ecf1f..6a1f479 100644
--- a/drivers/staging/media/omap24xx/tcm825x.c
+++ b/drivers/staging/media/omap24xx/tcm825x.c
@@ -751,7 +751,7 @@ static int ioctl_g_ifparm(struct v4l2_int_device *s, struct v4l2_ifparm *p)
(2457 * tgt_fps) / MAX_FPS;
tgt_xclk *= 10000;
- tgt_xclk = min(tgt_xclk, (u32)TCM825X_XCLK_MAX);
+ tgt_xclk = min_t(u32, tgt_xclk, TCM825X_XCLK_MAX);
tgt_xclk = max(tgt_xclk, (u32)TCM825X_XCLK_MIN);
p->u.bt656.clock_curr = tgt_xclk; |
tgt_xclk *= 10000;
