iio: adc: spmi-vadc: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each iteration,
so a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_available_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Cc:
Signed-off-by: Jonathan Cameron
 drivers/iio/adc/qcom-spmi-vadc.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/iio/adc/qcom-spmi-vadc.c b/drivers/iio/adc/qcom-spmi-vadc.c
index 0c4618b..c2babe5 100644
--- a/drivers/iio/adc/qcom-spmi-vadc.c
+++ b/drivers/iio/adc/qcom-spmi-vadc.c
@@ -839,8 +839,10 @@ static int vadc_get_dt_data(struct vadc_priv *vadc, struct device_node *node)
 	for_each_available_child_of_node(node, child) {
 		ret = vadc_get_dt_channel_data(vadc->dev, &prop, child);
-		if (ret)
+		if (ret) {
 			return ret;
 		vadc->chan_props[index] = prop;
BtrLinux
Privacy Overview
