power/reset: at91-reset: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_matching_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression e,e1;
local idexpression np;
for_each_matching_node(np, e1) {
... when != of_node_put(np)
when != e = np
return np;
+ of_node_put(np);
? return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Sebastian Reichel
drivers/power/reset/at91-reset.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/power/reset/at91-reset.c b/drivers/power/reset/at91-reset.c
index 3f6b5dd..1b5d450 100644
--- a/drivers/power/reset/at91-reset.c
+++ b/drivers/power/reset/at91-reset.c
@@ -198,6 +198,7 @@ static int __init at91_reset_probe(struct platform_device *pdev)
at91_ramc_base[idx] = of_iomap(np, 0);
if (!at91_ramc_base[idx]) {
dev_err(&pdev->dev, "Could not map ram controller address\n");
+ of_node_put(np);
return -ENODEV;
idx++; |
+ of_node_put(np);
return -ENODEV;
idx++;
