hwmon: Make PCI device ids constant
Author: Márton Németh <nm127@freemail.hu>
The id_table field of the struct pci_driver is constant in
so it is worth to make pci_device_id also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Signed-off-by: Jean Delvare
 drivers/hwmon/k10temp.c | 2 +-
 drivers/hwmon/k8temp.c  | 2 +-
 drivers/hwmon/sis5595.c | 2 +-
 drivers/hwmon/via686a.c | 2 +-
 drivers/hwmon/vt8231.c  | 2 +-
 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/hwmon/k10temp.c b/drivers/hwmon/k10temp.c
index 4c9d349..099a213 100644
--- a/drivers/hwmon/k10temp.c
+++ b/drivers/hwmon/k10temp.c
@@ -195,7 +195,7 @@ static void __devexit k10temp_remove(struct pci_dev *pdev)
 	dev_set_drvdata(&pdev->dev, NULL);
-static struct pci_device_id k10temp_id_table[] = {
+static const struct pci_device_id k10temp_id_table[] = {
 	{ PCI_VDEVICE(AMD, PCI_DEVICE_ID_AMD_10H_NB_MISC) },
 	{ PCI_VDEVICE(AMD, PCI_DEVICE_ID_AMD_11H_NB_MISC) },
diff --git a/drivers/hwmon/k8temp.c b/drivers/hwmon/k8temp.c
index 1fe9951..0ceb6d6 100644
--- a/drivers/hwmon/k8temp.c
+++ b/drivers/hwmon/k8temp.c
@@ -136,7 +136,7 @@ static SENSOR_DEVICE_ATTR_2(temp3_input, S_IRUGO, show_temp, NULL, 1, 0);
 static SENSOR_DEVICE_ATTR_2(temp4_input, S_IRUGO, show_temp, NULL, 1, 1);
 static DEVICE_ATTR(name, S_IRUGO, show_name, NULL);
-static struct pci_device_id k8temp_ids[] = {
+static const struct pci_device_id k8temp_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_AMD, PCI_DEVICE_ID_AMD_K8_NB_MISC) },
 	{ 0 },
diff --git a/drivers/hwmon/sis5595.c b/drivers/hwmon/sis5595.c
index 12f2e70..79c2931 100644
--- a/drivers/hwmon/sis5595.c
+++ b/drivers/hwmon/sis5595.c
@@ -697,7 +697,7 @@ static struct sis5595_data *sis5595_update_device(struct device *dev)
 	return data;
-static struct pci_device_id sis5595_pci_ids[] = {
+static const struct pci_device_id sis5595_pci_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_SI, PCI_DEVICE_ID_SI_503) },
 	{ 0, }
diff --git a/drivers/hwmon/via686a.c b/drivers/hwmon/via686a.c
index 39e82a4..f397ce7 100644
--- a/drivers/hwmon/via686a.c
+++ b/drivers/hwmon/via686a.c
@@ -767,7 +767,7 @@ static struct via686a_data *via686a_update_device(struct device *dev)
 	return data;
-static struct pci_device_id via686a_pci_ids[] = {
+static const struct pci_device_id via686a_pci_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_82C686_4) },
 	{ 0, }
diff --git a/drivers/hwmon/vt8231.c b/drivers/hwmon/vt8231.c
index 470a122..d47b4c9 100644
--- a/drivers/hwmon/vt8231.c
+++ b/drivers/hwmon/vt8231.c
@@ -697,7 +697,7 @@ static struct platform_driver vt8231_driver = {
 	.remove	= __devexit_p(vt8231_remove),
-static struct pci_device_id vt8231_pci_ids[] = {
+static const struct pci_device_id vt8231_pci_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_8231_4) },
 	{ 0, }
BtrLinux
Privacy Overview
