drivers/block/drbd/drbd_receiver.c: correct NULL test
Test the just-allocated value for NULL rather than some other value.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,y;
statement S;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
if ((x) == NULL) S
if (
- y
+ x
== NULL)
S
Signed-off-by: Julia Lawall
Cc: Lars Ellenberg
Cc: Philipp Reisner
Signed-off-by: Andrew Morton
Signed-off-by: Jens Axboe
drivers/block/drbd/drbd_receiver.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/drbd/drbd_receiver.c b/drivers/block/drbd/drbd_receiver.c
index a6d266e..dbd4519 100644
--- a/drivers/block/drbd/drbd_receiver.c
+++ b/drivers/block/drbd/drbd_receiver.c
@@ -3945,7 +3945,7 @@ static int drbd_do_auth(struct drbd_conf *mdev)
right_response = kmalloc(resp_size, GFP_NOIO);
- if (response == NULL) {
+ if (right_response == NULL) {
dev_err(DEV, "kmalloc of right_response failed\n");
rv = 0;
goto fail; |
rv = 0;
goto fail;
