fs/autofs4: use memdup_user
Use memdup_user when user data is immediately copied into the allocated
region.  Elimination of the variable ads, which is no longer useful.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Cc: Ian Kent
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/autofs4/dev-ioctl.c | 13 ++-----------
 1 file changed, 2 insertions(+), 11 deletions(-)
diff --git a/fs/autofs4/dev-ioctl.c b/fs/autofs4/dev-ioctl.c
index d832062..ba4a38b 100644
--- a/fs/autofs4/dev-ioctl.c
+++ b/fs/autofs4/dev-ioctl.c
@@ -95,7 +95,7 @@ static int check_dev_ioctl_version(int cmd, struct autofs_dev_ioctl *param)
 static struct autofs_dev_ioctl *copy_dev_ioctl(struct autofs_dev_ioctl __user *in)
-	struct autofs_dev_ioctl tmp, *ads;
+	struct autofs_dev_ioctl tmp;
 	if (copy_from_user(&tmp, in, sizeof(tmp)))
 		return ERR_PTR(-EFAULT);
@@ -103,16 +103,7 @@ static struct autofs_dev_ioctl *copy_dev_ioctl(struct autofs_dev_ioctl __user *i
 	if (tmp.size < sizeof(tmp))
 		return ERR_PTR(-EINVAL);
-	ads = kmalloc(tmp.size, GFP_KERNEL);
-	if (!ads)
-		return ERR_PTR(-ENOMEM);
-	if (copy_from_user(ads, in, tmp.size)) {
-		kfree(ads);
-		return ERR_PTR(-EFAULT);
-	return ads;
+	return memdup_user(in, tmp.size);
 static inline void free_dev_ioctl(struct autofs_dev_ioctl *param)
BtrLinux
Privacy Overview
