drm/i2c: tda998x: fix misspelling of current function in string
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: Russell King
drivers/gpu/drm/i2c/tda998x_drv.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpu/drm/i2c/tda998x_drv.c b/drivers/gpu/drm/i2c/tda998x_drv.c
index 4dcf474..d853ab5 100644
--- a/drivers/gpu/drm/i2c/tda998x_drv.c
+++ b/drivers/gpu/drm/i2c/tda998x_drv.c
@@ -386,7 +386,7 @@ set_page(struct tda998x_priv *priv, uint16_t reg)
int ret = i2c_master_send(client, buf, sizeof(buf));
if (ret < 0) {
- dev_err(&client->dev, "setpage %04x err %d\n",
+ dev_err(&client->dev, "%s %04x err %d\n", __func__,
reg, ret);
return ret;
if (ret < 0) {
reg, ret);
return ret;
