usb: gadget: fix misspelling of current function in string
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: Felipe Balbi
drivers/usb/gadget/function/f_hid.c | 5 +++--
drivers/usb/gadget/function/f_midi.c | 2 +-
2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/gadget/function/f_hid.c b/drivers/usb/gadget/function/f_hid.c
index 6e04e30..a1bc3e3 100644
--- a/drivers/usb/gadget/function/f_hid.c
+++ b/drivers/usb/gadget/function/f_hid.c
@@ -399,8 +399,9 @@ static int hidg_setup(struct usb_function *f,
value = __le16_to_cpu(ctrl->wValue);
length = __le16_to_cpu(ctrl->wLength);
- VDBG(cdev, "hid_setup crtl_request : bRequestType:0x%x bRequest:0x%x "
- "Value:0x%x\n", ctrl->bRequestType, ctrl->bRequest, value);
+ VDBG(cdev,
+ "%s crtl_request : bRequestType:0x%x bRequest:0x%x Value:0x%x\n",
+ __func__, ctrl->bRequestType, ctrl->bRequest, value);
switch ((ctrl->bRequestType << 8) | ctrl->bRequest) {
case ((USB_DIR_IN | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8
diff --git a/drivers/usb/gadget/function/f_midi.c b/drivers/usb/gadget/function/f_midi.c
index a904403..259b656 100644
--- a/drivers/usb/gadget/function/f_midi.c
+++ b/drivers/usb/gadget/function/f_midi.c
@@ -520,7 +520,7 @@ static void f_midi_transmit(struct f_midi *midi, struct usb_request *req)
req = midi_alloc_ep_req(ep, midi->buflen);
if (!req) {
- ERROR(midi, "gmidi_transmit: alloc_ep_request failed\n");
+ ERROR(midi, "%s: alloc_ep_request failed\n", __func__);
return;
req->length = 0; |
+ VDBG(cdev,
if (!req) {
return;
req->length = 0;
