drm/dp/mst: constify drm_dp_mst_topology_cbs structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The drm_dp_mst_topology_cbs structures are never modified, so declare them
as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/intel_dp_mst.c    | 2 +-
 drivers/gpu/drm/radeon/radeon_dp_mst.c | 2 +-
 include/drm/drm_dp_mst_helper.h        | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/gpu/drm/i915/intel_dp_mst.c b/drivers/gpu/drm/i915/intel_dp_mst.c
index e8d369d..9ae1a4f 100644
--- a/drivers/gpu/drm/i915/intel_dp_mst.c
+++ b/drivers/gpu/drm/i915/intel_dp_mst.c
@@ -512,7 +512,7 @@ static void intel_dp_mst_hotplug(struct drm_dp_mst_topology_mgr *mgr)
 	drm_kms_helper_hotplug_event(dev);
-static struct drm_dp_mst_topology_cbs mst_cbs = {
+static const struct drm_dp_mst_topology_cbs mst_cbs = {
 	.add_connector = intel_dp_add_mst_connector,
 	.register_connector = intel_dp_register_mst_connector,
 	.destroy_connector = intel_dp_destroy_mst_connector,
diff --git a/drivers/gpu/drm/radeon/radeon_dp_mst.c b/drivers/gpu/drm/radeon/radeon_dp_mst.c
index 94323f5..8a02225 100644
--- a/drivers/gpu/drm/radeon/radeon_dp_mst.c
+++ b/drivers/gpu/drm/radeon/radeon_dp_mst.c
@@ -329,7 +329,7 @@ static void radeon_dp_mst_hotplug(struct drm_dp_mst_topology_mgr *mgr)
-struct drm_dp_mst_topology_cbs mst_cbs = {
+const struct drm_dp_mst_topology_cbs mst_cbs = {
 	.add_connector = radeon_dp_add_mst_connector,
 	.register_connector = radeon_dp_register_mst_connector,
 	.destroy_connector = radeon_dp_destroy_mst_connector,
diff --git a/include/drm/drm_dp_mst_helper.h b/include/drm/drm_dp_mst_helper.h
index 5340099..1666371 100644
--- a/include/drm/drm_dp_mst_helper.h
+++ b/include/drm/drm_dp_mst_helper.h
@@ -420,7 +420,7 @@ struct drm_dp_payload {
 struct drm_dp_mst_topology_mgr {
 	struct device *dev;
-	struct drm_dp_mst_topology_cbs *cbs;
+	const struct drm_dp_mst_topology_cbs *cbs;
 	int max_dpcd_transaction_bytes;
 	struct drm_dp_aux *aux; /* auxch for this topology mgr to use */
 	int max_payloads;
BtrLinux
Privacy Overview
