quota: constify qtree_fmt_operations structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The qtree_fmt_operations structures are never modified, so declare them as
const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Jan Kara
fs/ocfs2/quota.h | 2 +-
fs/ocfs2/quota_global.c | 2 +-
fs/quota/quota_v2.c | 4 ++--
include/linux/dqblk_qtree.h | 2 +-
4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/fs/ocfs2/quota.h b/fs/ocfs2/quota.h
index b6d5133..d153e6e 100644
--- a/fs/ocfs2/quota.h
+++ b/fs/ocfs2/quota.h
@@ -82,7 +82,7 @@ struct ocfs2_quota_chunk {
extern struct kmem_cache *ocfs2_dquot_cachep;
extern struct kmem_cache *ocfs2_qf_chunk_cachep;
-extern struct qtree_fmt_operations ocfs2_global_ops;
+extern const struct qtree_fmt_operations ocfs2_global_ops;
struct ocfs2_quota_recovery *ocfs2_begin_quota_recovery(
struct ocfs2_super *osb, int slot_num);
diff --git a/fs/ocfs2/quota_global.c b/fs/ocfs2/quota_global.c
index c93d6722..fde9ef1 100644
--- a/fs/ocfs2/quota_global.c
+++ b/fs/ocfs2/quota_global.c
@@ -123,7 +123,7 @@ static int ocfs2_global_is_id(void *dp, struct dquot *dquot)
dquot->dq_id);
-struct qtree_fmt_operations ocfs2_global_ops = {
+const struct qtree_fmt_operations ocfs2_global_ops = {
.mem2disk_dqblk = ocfs2_global_mem2diskdqb,
.disk2mem_dqblk = ocfs2_global_disk2memdqb,
.is_id = ocfs2_global_is_id,
diff --git a/fs/quota/quota_v2.c b/fs/quota/quota_v2.c
index 2aa012a..ed85d4f 100644
--- a/fs/quota/quota_v2.c
+++ b/fs/quota/quota_v2.c
@@ -30,13 +30,13 @@ static void v2r1_mem2diskdqb(void *dp, struct dquot *dquot);
static void v2r1_disk2memdqb(struct dquot *dquot, void *dp);
static int v2r1_is_id(void *dp, struct dquot *dquot);
-static struct qtree_fmt_operations v2r0_qtree_ops = {
+static const struct qtree_fmt_operations v2r0_qtree_ops = {
.mem2disk_dqblk = v2r0_mem2diskdqb,
.disk2mem_dqblk = v2r0_disk2memdqb,
.is_id = v2r0_is_id,
-static struct qtree_fmt_operations v2r1_qtree_ops = {
+static const struct qtree_fmt_operations v2r1_qtree_ops = {
.mem2disk_dqblk = v2r1_mem2diskdqb,
.disk2mem_dqblk = v2r1_disk2memdqb,
.is_id = v2r1_is_id,
diff --git a/include/linux/dqblk_qtree.h b/include/linux/dqblk_qtree.h
index 82a1652..ff8b553 100644
--- a/include/linux/dqblk_qtree.h
+++ b/include/linux/dqblk_qtree.h
@@ -34,7 +34,7 @@ struct qtree_mem_dqinfo {
unsigned int dqi_entry_size; /* Size of quota entry in quota file */
unsigned int dqi_usable_bs; /* Space usable in block for quota data */
unsigned int dqi_qtree_depth; /* Precomputed depth of quota tree */
- struct qtree_fmt_operations *dqi_ops; /* Operations for entry manipulation */
+ const struct qtree_fmt_operations *dqi_ops; /* Operations for entry manipulation */
int qtree_write_dquot(struct qtree_mem_dqinfo *info, struct dquot *dquot); |
dquot->dq_id);
