drm: rcar-du: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Propagate the error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Laurent Pinchart
 drivers/gpu/drm/rcar-du/rcar_du_crtc.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
index 088bfd8..23cc910 100644
--- a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
+++ b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
@@ -586,7 +586,7 @@ int rcar_du_crtc_create(struct rcar_du_group *rgrp, unsigned int index)
 	if (irq < 0) {
 		dev_err(rcdu->dev, "no IRQ for CRTC %u\n", index);
-		return ret;
+		return irq;
 	ret = devm_request_irq(rcdu->dev, irq, rcar_du_crtc_irq, irqflags,
BtrLinux
Privacy Overview
