drivers/video/sunxvr500.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Florian Tobias Schandinat
 drivers/video/sunxvr500.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/video/sunxvr500.c b/drivers/video/sunxvr500.c
index eb931b8..6c71b1b 100644
--- a/drivers/video/sunxvr500.c
+++ b/drivers/video/sunxvr500.c
@@ -298,8 +298,10 @@ static int __devinit e3d_pci_register(struct pci_dev *pdev,
 		goto err_release_fb;
 	ep->ramdac = ioremap(ep->regs_base_phys + 0x8000, 0x1000);
-	if (!ep->ramdac)
+	if (!ep->ramdac) {
+		err = -ENOMEM;
 		goto err_release_pci1;
 	ep->fb8_0_off = readl(ep->ramdac + RAMDAC_VID_8FB_0);
 	ep->fb8_0_off -= ep->fb_base_reg;
@@ -343,8 +345,10 @@ static int __devinit e3d_pci_register(struct pci_dev *pdev,
 	ep->fb_size = info->fix.line_length * ep->height;
 	ep->fb_base = ioremap(ep->fb_base_phys, ep->fb_size);
-	if (!ep->fb_base)
+	if (!ep->fb_base) {
+		err = -ENOMEM;
 		goto err_release_pci0;
 	err = e3d_set_fbinfo(ep);
 	if (err)
BtrLinux
Privacy Overview
