drivers/video/atmel_lcdfb.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Florian Tobias Schandinat
 drivers/video/atmel_lcdfb.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c
index 1505539..94cac9f 100644
--- a/drivers/video/atmel_lcdfb.c
+++ b/drivers/video/atmel_lcdfb.c
@@ -931,8 +931,10 @@ static int __init atmel_lcdfb_probe(struct platform_device *pdev)
 		info->screen_base = ioremap(info->fix.smem_start, info->fix.smem_len);
-		if (!info->screen_base)
+		if (!info->screen_base) {
+			ret = -ENOMEM;
 			goto release_intmem;
 		 * Don't clear the framebuffer -- someone may have set
@@ -960,6 +962,7 @@ static int __init atmel_lcdfb_probe(struct platform_device *pdev)
 	sinfo->mmio = ioremap(info->fix.mmio_start, info->fix.mmio_len);
 	if (!sinfo->mmio) {
 		dev_err(dev, "cannot map LCDC registers\n");
+		ret = -ENOMEM;
 		goto release_mem;
BtrLinux
Privacy Overview
