drivers/usb/host/ehci-fsl.c: add missing iounmap
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Add missing iounmap in error handling code, in a case where the function
already preforms iounmap on some other execution path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e;
statement S,S1;
int ret;
e = \(ioremap\|ioremap_nocache\)(...)
... when != iounmap(e)
if (<+...e...+>) S
... when any
    when != iounmap(e)
*if (...)
   { ... when != iounmap(e)
     return ...; }
... when any
iounmap(e);
Signed-off-by: Julia Lawall
Acked-by: Alan Stern
Cc: stable
 drivers/usb/host/ehci-fsl.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c
index e90344a..b556a72 100644
--- a/drivers/usb/host/ehci-fsl.c
+++ b/drivers/usb/host/ehci-fsl.c
@@ -125,7 +125,7 @@ static int usb_hcd_fsl_probe(const struct hc_driver *driver,
 	if (pdata->init && pdata->init(pdev)) {
 		retval = -ENODEV;
-		goto err3;
+		goto err4;
 	/* Enable USB controller, 83xx or 8536 */
BtrLinux
Privacy Overview
