arch/powerpc/sysdev/fsl_pci.c: add missing iounmap
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Add missing iounmap in error handling code, in a case where the function
already preforms iounmap on some other execution path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e;
statement S,S1;
int ret;
e = \(ioremap\|ioremap_nocache\)(...)
... when != iounmap(e)
if (<+...e...+>) S
... when any
when != iounmap(e)
*if (...)
{ ... when != iounmap(e)
return ...; }
... when any
iounmap(e);
Signed-off-by: Julia Lawall
Signed-off-by: Kumar Gala
arch/powerpc/sysdev/fsl_pci.c | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/sysdev/fsl_pci.c b/arch/powerpc/sysdev/fsl_pci.c
index 3b61e8c..30eb17e 100644
--- a/arch/powerpc/sysdev/fsl_pci.c
+++ b/arch/powerpc/sysdev/fsl_pci.c
@@ -205,12 +205,12 @@ static void __init setup_pci_atmu(struct pci_controller *hose,
if (paddr_hi == paddr_lo) {
pr_err("%s: No outbound window space\n", name);
- return ;
+ goto out;
if (paddr_lo == 0) {
pr_err("%s: No space for inbound window\n", name);
- return ;
+ goto out;
/* setup PCSRBAR/PEXCSRBAR */
@@ -357,6 +357,7 @@ static void __init setup_pci_atmu(struct pci_controller *hose,
(u64)hose->dma_window_size);
+out:
iounmap(pci);
- return ;
+ goto out;
- return ;
+ goto out;
+out:
iounmap(pci);
