drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree
Glue needs to be freed on exiting the function in an error case.
Furthermore, pci, which is the first argument to the probe function should
not be freed before leaveing the function, as it is reused at the call
site.  So the free of pci is changed to free glue instead.
A simplified version of the semantic match that finds the problem is as
follows: (http://coccinelle.lip6.fr)
@r exists@
local idexpression x;
statement S;
identifier f1;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
 drivers/usb/dwc3/dwc3-pci.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-pci.c b/drivers/usb/dwc3/dwc3-pci.c
index cd1429f..64e1f7c 100644
--- a/drivers/usb/dwc3/dwc3-pci.c
+++ b/drivers/usb/dwc3/dwc3-pci.c
@@ -134,7 +134,7 @@ err2:
 	pci_disable_device(pci);
 err1:
-	kfree(pci);
+	kfree(glue);
 err0:
 	return ret;
BtrLinux
Privacy Overview
