net/rfkill/rfkill-gpio.c: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The label fail_alloc already does this for rfkill.
A simplified version of the semantic match that finds the problem is as
follows: (http://coccinelle.lip6.fr)
@r exists@
local idexpression x;
statement S;
identifier f1;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
net/rfkill/rfkill-gpio.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/rfkill/rfkill-gpio.c b/net/rfkill/rfkill-gpio.c
index ca355e7..865adb6 100644
--- a/net/rfkill/rfkill-gpio.c
+++ b/net/rfkill/rfkill-gpio.c
@@ -105,7 +105,7 @@ static int rfkill_gpio_probe(struct platform_device *pdev)
ret = pdata->gpio_runtime_setup(pdev);
if (ret) {
pr_warn("%s: can't set up gpio\n", __func__);
- return ret;
+ goto fail_alloc;
if (ret) {
- return ret;
+ goto fail_alloc;
