drivers/tty/moxa.c: Put correct tty value
The tty value that should be put is the one that was just gotten by
tty_port_tty_get, not the one that is the argument to the enclosing
function.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@exists@
local idexpression struct tty_struct *x;
expression ra,rr;
statement S1,S2;
x = tty_port_tty_get(...)
... when != x = rr
when any
when != tty_kref_put(x,...)
when != if (...) { ... tty_kref_put(x,...) ...}
if(<+...x...+>) S1 else S2
if(...) { ... when != x = ra
when forall
*return...;
Signed-off-by: Julia Lawall
drivers/tty/moxa.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/tty/moxa.c b/drivers/tty/moxa.c
index 6255561..ba679ce 100644
--- a/drivers/tty/moxa.c
+++ b/drivers/tty/moxa.c
@@ -371,7 +371,7 @@ static int moxa_ioctl(struct tty_struct *tty,
tmp.cflag = p->cflag;
else
tmp.cflag = ttyp->termios->c_cflag;
- tty_kref_put(tty);
+ tty_kref_put(ttyp);
copy:
if (copy_to_user(argm, &tmp, sizeof(tmp)))
return -EFAULT; |
else
copy:
return -EFAULT;
