[SCSI] hpsa: Change memset using sizeof(ptr) to sizeof(*ptr)
Author: Joe Perches <joe@perches.com>
Not at all sure this is correct or appropriate to change,
but this seems odd.
Found via coccinelle script
type T;
T* ptr;
expression E1;
* memset(E1, 0, sizeof(ptr));
Signed-off-by: Joe Perches
Acked-by: Stephen M. Cameron
Signed-off-by: James Bottomley
drivers/scsi/hpsa.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/scsi/hpsa.c b/drivers/scsi/hpsa.c
index cffc7bb..c6c0434 100644
--- a/drivers/scsi/hpsa.c
+++ b/drivers/scsi/hpsa.c
@@ -1329,7 +1329,7 @@ static void hpsa_scsi_do_simple_cmd_with_retry(struct ctlr_info *h,
int retry_count = 0;
do {
- memset(c->err_info, 0, sizeof(c->err_info));
+ memset(c->err_info, 0, sizeof(*c->err_info));
hpsa_scsi_do_simple_cmd_core(h, c);
retry_count++;
} while (check_for_unit_attention(h, c) && retry_count <= 3); |
do {
retry_count++;
