drivers/tty/moxa.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
    when != ret = e3
*if (x == NULL || ...)
  ... when != ret = e4
*  return ret;
Signed-off-by: Julia Lawall
 drivers/tty/moxa.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/tty/moxa.c b/drivers/tty/moxa.c
index 9dffc72..3b17a04 100644
--- a/drivers/tty/moxa.c
+++ b/drivers/tty/moxa.c
@@ -977,6 +977,7 @@ static int __devinit moxa_pci_probe(struct pci_dev *pdev,
 	board->basemem = ioremap_nocache(pci_resource_start(pdev, 2), 0x4000);
 	if (board->basemem == NULL) {
 		dev_err(&pdev->dev, "can't remap io space 2\n");
+		retval = -ENOMEM;
 		goto err_reg;
BtrLinux
Privacy Overview
