drivers/usb/gadget/s3c-hsotg.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
when != ret = e3
*if (x == NULL || ...)
... when != ret = e4
* return ret;
Signed-off-by: Julia Lawall
drivers/usb/gadget/s3c-hsotg.c | 3 +++
1 file changed, 3 insertions(+)
diff --git a/drivers/usb/gadget/s3c-hsotg.c b/drivers/usb/gadget/s3c-hsotg.c
index b13e0bb..0bb617e 100644
--- a/drivers/usb/gadget/s3c-hsotg.c
+++ b/drivers/usb/gadget/s3c-hsotg.c
@@ -3599,6 +3599,7 @@ static int __devinit s3c_hsotg_probe(struct platform_device *pdev)
if (hsotg->num_of_eps == 0) {
dev_err(dev, "wrong number of EPs (zero)\n");
+ ret = -EINVAL;
goto err_supplies;
@@ -3606,6 +3607,7 @@ static int __devinit s3c_hsotg_probe(struct platform_device *pdev)
GFP_KERNEL);
if (!eps) {
dev_err(dev, "cannot get memory\n");
+ ret = -ENOMEM;
goto err_supplies;
@@ -3622,6 +3624,7 @@ static int __devinit s3c_hsotg_probe(struct platform_device *pdev)
GFP_KERNEL);
if (!hsotg->ctrl_req) {
dev_err(dev, "failed to allocate ctrl req\n");
+ ret = -ENOMEM;
goto err_ep_mem;
+ ret = -EINVAL;
goto err_supplies;
GFP_KERNEL);
if (!eps) {
+ ret = -ENOMEM;
goto err_supplies;
GFP_KERNEL);
+ ret = -ENOMEM;
goto err_ep_mem;
