drivers/telephony/ixj.c: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/telephony/ixj.c | 15 ++++-----------
 1 file changed, 4 insertions(+), 11 deletions(-)
diff --git a/drivers/telephony/ixj.c b/drivers/telephony/ixj.c
index e89304c..b53deee 100644
--- a/drivers/telephony/ixj.c
+++ b/drivers/telephony/ixj.c
@@ -5879,20 +5879,13 @@ out:
 static int ixj_build_filter_cadence(IXJ *j, IXJ_FILTER_CADENCE __user * cp)
 	IXJ_FILTER_CADENCE *lcp;
-	lcp = kmalloc(sizeof(IXJ_FILTER_CADENCE), GFP_KERNEL);
-	if (lcp == NULL) {
+	lcp = memdup_user(cp, sizeof(IXJ_FILTER_CADENCE));
+	if (IS_ERR(lcp)) {
 		if(ixjdebug & 0x0001) {
-			printk(KERN_INFO "Could not allocate memory for cadence\n");
+			printk(KERN_INFO "Could not allocate memory for cadence or could not copy cadence to kernel\n");
-		return -ENOMEM;
+		return PTR_ERR(lcp);
-	if (copy_from_user(lcp, cp, sizeof(IXJ_FILTER_CADENCE))) {
-		if(ixjdebug & 0x0001) {
-			printk(KERN_INFO "Could not copy cadence to kernel\n");
-		kfree(lcp);
-		return -EFAULT;
 	if (lcp->filter > 5) {
 			printk(KERN_INFO "Cadence out of range\n");
BtrLinux
Privacy Overview
