ipc/sem.c: use ERR_CAST
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
Signed-off-by: Julia Lawall
Cc: Manfred Spraul
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
ipc/sem.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/ipc/sem.c b/ipc/sem.c
index 5b33228..506c849 100644
--- a/ipc/sem.c
+++ b/ipc/sem.c
@@ -1208,7 +1208,7 @@ static struct sem_undo *find_alloc_undo(struct ipc_namespace *ns, int semid)
/* step 1: figure out the size of the semaphore array */
sma = sem_lock_check(ns, semid);
if (IS_ERR(sma))
- return ERR_PTR(PTR_ERR(sma));
+ return ERR_CAST(sma);
nsems = sma->sem_nsems;
sem_getref_and_unlock(sma); |
ipc/sem.c | 2 +-
--- a/ipc/sem.c
+++ b/ipc/sem.c
if (IS_ERR(sma))
