drivers/staging/rtl8192u/r8192U_core.c: Remove useless kfree
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
                        when != e = e1
                        when != e += e1
                        when != e -= e1
                        when != ++e
                        when != --e
                        when != e++
                        when != e--
                        when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
 drivers/staging/rtl8192u/r8192U_core.c | 23 +++++++----------------
 1 file changed, 7 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index 5c132ac..5a2fab9 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -2232,24 +2232,15 @@ short rtl8192_usb_initendpoints(struct net_device *dev)
 	memset(priv->rx_urb, 0, sizeof(struct urb*) * MAX_RX_URB);
 	priv->pp_rxskb = kcalloc(MAX_RX_URB, sizeof(struct sk_buff *),
 				 GFP_KERNEL);
-	if (priv->pp_rxskb == NULL)
-		goto destroy;
-	goto _middle;
-destroy:
-	kfree(priv->pp_rxskb);
-	kfree(priv->rx_urb);
-	priv->pp_rxskb = NULL;
-	priv->rx_urb = NULL;
-	DMESGE("Endpoint Alloc Failure");
-	return -ENOMEM;
+	if (!priv->pp_rxskb) {
+		kfree(priv->rx_urb);
+		priv->pp_rxskb = NULL;
+		priv->rx_urb = NULL;
-_middle:
+		DMESGE("Endpoint Alloc Failure");
+		return -ENOMEM;
 	printk("End of initendpoints\n");
 	return 0;
BtrLinux
Privacy Overview
