drivers/staging/gdm72xx/gdm_sdio.c: Remove useless kfree
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
when != e = e1
when != e += e1
when != e -= e1
when != ++e
when != --e
when != e++
when != e--
when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
drivers/staging/gdm72xx/gdm_sdio.c | 7 ++-----
1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/gdm72xx/gdm_sdio.c b/drivers/staging/gdm72xx/gdm_sdio.c
index f824290..a0621d9 100644
--- a/drivers/staging/gdm72xx/gdm_sdio.c
+++ b/drivers/staging/gdm72xx/gdm_sdio.c
@@ -94,17 +94,14 @@ static struct sdio_rx *alloc_rx_struct(struct rx_cxt *rx)
struct sdio_rx *r = NULL;
r = kmalloc(sizeof(*r), GFP_ATOMIC);
- if (r == NULL)
- goto out;
+ if (!r)
+ return NULL;
memset(r, 0, sizeof(*r));
r->rx_cxt = rx;
return r;
-out:
- kfree(r);
- return NULL;
static void free_rx_struct(struct sdio_rx *r) |
- if (r == NULL)
- goto out;
+ if (!r)
+ return NULL;
r->rx_cxt = rx;
return r;
-out:
- kfree(r);
- return NULL;
