drivers/staging/intel_sst/intel_sst_app_interface.c: introduce missing kfree
Stream_bufs is initialized at the beginning of the function, and then the
#ifdef code declares a new variable with the same name and initializes
that.  If the if in the ifdef is taken, the then branch returns, implying
that the first stream_bufs is never used and is leaked.  The first
initialization is thus moved down after the ifdef.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
 drivers/staging/intel_sst/intel_sst_app_interface.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/intel_sst/intel_sst_app_interface.c b/drivers/staging/intel_sst/intel_sst_app_interface.c
index 1d06212..d7454e2 100644
--- a/drivers/staging/intel_sst/intel_sst_app_interface.c
+++ b/drivers/staging/intel_sst/intel_sst_app_interface.c
@@ -418,10 +418,6 @@ static int snd_sst_fill_kernel_list(struct stream_info *stream,
 	static int sent_offset;
 	static unsigned long sent_index;
-	stream_bufs = kzalloc(sizeof(*stream_bufs), GFP_KERNEL);
-	if (!stream_bufs)
-		return -ENOMEM;
-	stream_bufs->addr = sst_drv_ctx->mmap_mem;
 #ifdef CONFIG_MRST_RAR_HANDLER
 	if (stream->ops == STREAM_OPS_PLAYBACK_DRM) {
 		for (index = stream->sg_index; index < nr_segs; index++) {
@@ -448,6 +444,10 @@ static int snd_sst_fill_kernel_list(struct stream_info *stream,
 		return retval;
 #endif
+	stream_bufs = kzalloc(sizeof(*stream_bufs), GFP_KERNEL);
+	if (!stream_bufs)
+		return -ENOMEM;
+	stream_bufs->addr = sst_drv_ctx->mmap_mem;
 	mmap_len = sst_drv_ctx->mmap_len;
 	bufp = stream->cur_ptr;
BtrLinux
Privacy Overview
