drivers/staging/cx25821/cx25821-video.c: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
drivers/staging/cx25821/cx25821-video.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/staging/cx25821/cx25821-video.c b/drivers/staging/cx25821/cx25821-video.c
index ab05392..04b18f4 100644
--- a/drivers/staging/cx25821/cx25821-video.c
+++ b/drivers/staging/cx25821/cx25821-video.c
@@ -832,6 +832,7 @@ static int video_open(struct file *file)
if (NULL == dev) {
mutex_unlock(&cx25821_devlist_mutex);
+ kfree(fh);
return -ENODEV;
if (NULL == dev) {
+ kfree(fh);
return -ENODEV;
