drivers/pcmcia: Add missing local_irq_restore
Use local_irq_restore in this error-handling case just like in the one just
below.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression E1;
identifier f;
f (...) { <+...
* local_irq_save (E1,...);
... when != E1
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Dominik Brodowski
 drivers/pcmcia/db1xxx_ss.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/pcmcia/db1xxx_ss.c b/drivers/pcmcia/db1xxx_ss.c
index 6206408..2d48196 100644
--- a/drivers/pcmcia/db1xxx_ss.c
+++ b/drivers/pcmcia/db1xxx_ss.c
@@ -166,8 +166,10 @@ static int db1x_pcmcia_setup_irqs(struct db1x_pcmcia_sock *sock)
 		ret = request_irq(sock->insert_irq, db1200_pcmcia_cdirq,
 				  IRQF_DISABLED, "pcmcia_insert", sock);
-		if (ret)
+		if (ret) {
+			local_irq_restore(flags);
 			goto out1;
 		ret = request_irq(sock->eject_irq, db1200_pcmcia_cdirq,
 				  IRQF_DISABLED, "pcmcia_eject", sock);
BtrLinux
Privacy Overview
