USB: gadget: s3c-hsotg: Add missing unlock
In an error handling case the lock is not unlocked. The return is
converted to a goto, to share the unlock at the end of the function.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression E1;
identifier f;
f (...) { <+...
* spin_lock_irqsave (E1,...);
... when != E1
* return ...;
Signed-off-by: Julia Lawall
drivers/usb/gadget/s3c-hsotg.c | 7 +++++--
1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/s3c-hsotg.c b/drivers/usb/gadget/s3c-hsotg.c
index 124a8cc..1f73b48 100644
--- a/drivers/usb/gadget/s3c-hsotg.c
+++ b/drivers/usb/gadget/s3c-hsotg.c
@@ -2145,6 +2145,7 @@ static int s3c_hsotg_ep_enable(struct usb_ep *ep,
u32 epctrl;
u32 mps;
int dir_in;
+ int ret = 0;
dev_dbg(hsotg->dev,
"%s: ep %s: a 0x%02x, attr 0x%02x, mps 0x%04x, intr %d\n",
@@ -2196,7 +2197,8 @@ static int s3c_hsotg_ep_enable(struct usb_ep *ep,
switch (desc->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) {
case USB_ENDPOINT_XFER_ISOC:
dev_err(hsotg->dev, "no current ISOC support\n");
- return -EINVAL;
+ ret = -EINVAL;
+ goto out;
case USB_ENDPOINT_XFER_BULK:
epctrl |= S3C_DxEPCTL_EPType_Bulk;
@@ -2235,8 +2237,9 @@ static int s3c_hsotg_ep_enable(struct usb_ep *ep,
/* enable the endpoint interrupt */
s3c_hsotg_ctrl_epint(hsotg, index, dir_in, 1);
+out:
spin_unlock_irqrestore(&hs_ep->lock, flags);
- return 0;
+ return ret;
static int s3c_hsotg_ep_disable(struct usb_ep *ep) |
u32 epctrl;
u32 mps;
int dir_in;
+ int ret = 0;
dev_dbg(hsotg->dev,
- return -EINVAL;
+ ret = -EINVAL;
+ goto out;
+out:
- return 0;
+ return ret;
