Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
- to = \(kmalloc\|kzalloc\)(size,flag);
+ to = kmemdup(from,size,flag);
if (to==NULL || ...) S
- memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
drivers/net/wireless/wl12xx/wl1271_main.c | 8 ++------
1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/net/wireless/wl12xx/wl1271_main.c b/drivers/net/wireless/wl12xx/wl1271_main.c
index d30de58..864318f 100644
--- a/drivers/net/wireless/wl12xx/wl1271_main.c
+++ b/drivers/net/wireless/wl12xx/wl1271_main.c
@@ -576,7 +576,7 @@ static int wl1271_fetch_nvs(struct wl1271 *wl)
goto out;
- wl->nvs = kzalloc(sizeof(struct wl1271_nvs_file), GFP_KERNEL);
+ wl->nvs = kmemdup(fw->data, sizeof(struct wl1271_nvs_file), GFP_KERNEL);
if (!wl->nvs) {
wl1271_error("could not allocate memory for the nvs file");
@@ -584,8 +584,6 @@ static int wl1271_fetch_nvs(struct wl1271 *wl)
goto out;
- memcpy(wl->nvs, fw->data, fw->size);
out:
release_firmware(fw);
@@ -2350,15 +2348,13 @@ struct ieee80211_hw *wl1271_alloc_hw(void)
goto err_hw_alloc;
- plat_dev = kmalloc(sizeof(wl1271_device), GFP_KERNEL);
+ plat_dev = kmemdup(&wl1271_device, sizeof(wl1271_device), GFP_KERNEL);
if (!plat_dev) {
wl1271_error("could not allocate platform_device");
ret = -ENOMEM;
goto err_plat_alloc;
- memcpy(plat_dev, &wl1271_device, sizeof(wl1271_device));
wl = hw->priv;
memset(wl, 0, sizeof(*wl)); |
goto out;
if (!wl->nvs) {
goto out;
out:
goto err_hw_alloc;
if (!plat_dev) {
ret = -ENOMEM;
wl = hw->priv;
